Toyo Steering Billet Tundra Steering Rack
mrbrenan
official vendor
Finally, someone made a rack that was designed for our our specific chassis.
I already installed one of these on a 3rd Gen Tacoma and will be installing one on a 5th Gen 4Runner coming up here soon.
Installation Overview
Toyo Steering Billet Tundra Rack Install on Tacoma
Product Overview:
Toyo Steering Billet Steering Rack: First Look
If you’re running larger tires, steering becomes one of the first weak points. The new Toyo Steering Billet Rack was designed to address the limitations of traditional modified Tundra and LC200 rack swaps while maintaining OEM steering geometry and fitment.
Unlike legacy rack conversions that modify an OEM cast housing, the Toyo rack is built from the ground up using a fully billet 6061 T6 aluminum housing with Tundra internals machined specifically for Toyota SUV and truck platforms; 4Runner, GX, Tacoma, FJ, Etc.
One of the biggest advantages of the new rack is maintaining OEM equivalent pivots. Many LC200 and modified Tundra racks alter toe curves and steering characteristics throughout suspension travel. The Toyo rack keeps repositioning the mounting points and pinion angle to correct all the common steering issues with a modified tundra rack and LC200 racks.
The billet housing is machined to the proper width for each platform instead of reusing the wider Tundra housing. This allows full usable steering stroke without sacrificing steering angle or geometry.
The rack uses a 3 piece billet housing with bronze bushings at both ends to reduce deflection under load. Tight tolerances help improve seal life and steering precision compared to traditional modified cast housings.
The pinion is moved closer to center and angled upward slightly for improved u joint alignment and better clearance around the frame and suspension components. This eliminates the need for frame notching on many applications.
Supported platforms:
GX470
4th Gen 4Runner
Tacoma
GX460
5th Gen 4Runner
Each rack is built to order around the customer’s steering setup and tie rod configuration.
Materials & Components
6061 T6 billet aluminum housing
Bronze rack support bushings
OE grade seals
12 point mil spec hardware
Cadmium plated fasteners
5000 PSI hydraulic lines and fittings
Delrin and 17 4PH stainless bushings
For hard wheeling and larger tires, Toyo Steering recommends pairing the rack with an upgraded ps pump, and an inline cooler (which they will have full kits soon).
You can find a discount code on 4RunnerMods.com through Trail4R.com
5th Gen 4Runner Billet Tundra Steering Rack Kit – 4RunnerMods
If you have any questions on tierod configuration for your exact setup, whether factory length or LT, let me know and I can help walk you through thread pitch, diam, length and taper at the spindle.
More photos: Toyo Steering Billet Steering Rack: First Look
