20 Gallons
Oprah
Managed to get 20 gallons in her about 4 times now.... this is after driving a bit after the fuel gauge pegs at it's lowest point, and topping off to the point of seeing the gas at the top of the filler tube.
Yes yes I know I've heard the arguments regarding topping off, but I already have an issue with my charcoal canister so I've been goin for gold on tank range!
What's y'all's biggest fill-ups?
<center>
<a href="http://s375.photobucket.com/user/jhmiller22/media/IMAG0795_zps4hx1f0mw.jpg.html" target="_blank"><img src="http://i375.photobucket.com/albums/oo191/jhmiller22/IMAG0795_zps4hx1f0mw.jpg" border="0" alt=" photo IMAG0795_zps4hx1f0mw.jpg"/></a>
<a href="http://s375.photobucket.com/user/jhmiller22/media/IMAG0709_zpsg95nsm3y.jpg.html" target="_blank"><img src="http://i375.photobucket.com/albums/oo191/jhmiller22/IMAG0709_zpsg95nsm3y.jpg" border="0" alt=" photo IMAG0709_zpsg95nsm3y.jpg"/></a>
</center>
IDK Bro, you might have gotten less than you paid for. I just filled up after driving 50 miles with my gas light on and all I could get was 15 gal. But I could be wrong?
I think stock tanks are 19 gallons, so if you top it off to the neck that might be about right. I doubt anyone will post anything higher though.
He is filling up from nearly bone dry all the way up into the filler tube which is WAY over. He doesn't stop when the pump cuts off.
I've heard too many arguments on why topping off is a bad idea, even if your canister is ruined you probably don't want to top off. But 16.5 gal
That's interesting to hear. Since I've had my truck I've pretty regularly topped off 2 gallons after the pump cuts off, which usually nets between 18-19 gallons on an "empty" tank. Been doing that many different gas stations as well. So the 20 gallons didnt surprise me too much when pushing the limits of the tank by driving around for 20+ miles after the fuel gauge is completely pegged at the bottom (pegs at bottom around 30 miles after gas light comes on). In an 18.5 gallon tank
Way over is right haha, that's topping off about 2.2 gallons give or take. Besides the canister, what other reasons do you know of for not topping off?
Nothing personally, but gas tanks systems aren't meant to store gas in the filler tube so I'm sure it's a saftey hazard of some sort. I'm not sure exactly what though, I've just been told by mechanics that you shouldn't do it "just cuz"
It probably is not safe in an accident.
...Besides the canister, what other reasons do you know of for not topping off?
Well how about expansion? Depending on what time of day you fill, outside temps, brief drive home from your 20+ gal site could = too much pressure build up. I see it in just a 5 gal gas tank that i might fill to 95%, burp just before leaving it sit then return a couple hrs later, burp it to find lots of pressure escaping (all while in the shade). Not sure if that's good for the fuel system but I Gotta ask, WHY do this? :cowboy:
When topping off its draining into the canister. So you not even using that little amount of fuel. Wasteful and can cause gas fumes around the vehicle.
Also to op why you feel the need to post that you filled your tank? We all have to put gas in. Lol. 18.5 gal tanks. That's about what we all can fill.
Expansion is why, unless you like the gas fume smell there is no reason to run the risk of fire or worse. Even two gallons is only an extra 30-40 miles per tank, just not worth it.
But seriously, I'm just pissed that we pay almost a dollar more per gallon here in CA!!
:flamethrwoer2:
I have no idea how you get that much gas in there. You must be coasting into the gas station on fumes haha
:flamethrwoer2:
It's great here in Alabama. I paid $1.88 the other day and I live at the northern edge of Alabama, it usually gets cheaper the farther south you go too.
My truck is one that's affected by the screwed up tank sending unit, so even if it says it's bone dry I only put about 15 gallons in it. That sucks on road trips, but knowing that I have 3 gallons in reserve I'm going to start waiting until it's hit the E for a while before I stop. Not being able to get at least 300 miles on a tank on the highway is a PITA.
At least its better than my car. 13 gallons of E85 means fillups every 175 miles. :brick:
Suprised no one has brought up how hard it is on your fuel pump to be run so low on gas.
That's an old wives tale caused by some shoddy engineering by the domestic companies back when they first switched over to in tank fuel pumps. The morons were relying on them being submerged to keep them cool. They learned their lesson and you're not going to hurt them now.
Its not old wives tail when running a 450lph walbro fuel pump. But yeah thats mostly right. LOL.
So in theory it is a safety hazard while driving the first 40+ miles until the fuel level reaches back down to the bottom of the filler neck? The safety issue is that the gas is closer to the outside of the vehicle? Even if there isn't gas in the filler tube, isn't there gas fumes from the tank in the filler tube that could ignite maybe just as easily? Or is there some sort of valve there that closes between the tank and filler tube to keep fumes/gas out of the filler tube when the tank is filled to the proper level?
I'd assume that the pressure can escape somewhere in the system, maybe at the gas cap? Or via the canister system?
I haven't smelt any fumes around my truck after filling that I can recall. Only time would be if accidentally over flowed completely, but then that's only because there's gas outside of the filler tube at the top that spilled over. I'm not sure that it's emptying into the canister, I've seen tank range changes proportional to the amount of gas I've topped off which leads me to believe I do get the benefit of having the extra gas.
I posted the pictures because I've seen a lot of arguments in other threads about how much gas people put in, or how much is possible, what tank range people are getting, blah blah blah so I figured I'd show that this really has happened a few times.
And this is the reason why. I do a lot of "road trips" where I'm driving 7+ hours on the highway. A prime example is when I drive to my unfortunately far away located girlfriend's place for a weekend trip, if I top off, I can make the 9 hour trip with 1 stop for gas. If I don't top off, I have to stop 2 times. Now that doesn't sound like a big deal, but when you drive 9 hours on a friday, and are driving 9 hours back on sunday, those extra few minutes of time with your partner (or sleeping on Sunday for work Monday), or without, become much more important. Also when you are sacrificing to make that 9 hour drive a couple times a month for a few months, being able to feel confident you have mastered that route and can do it as quickly and efficiently is important to one's sanity (or at least mine) haha
2001ATL
