Just installed some Nitto's in 275/55/20 on my limited 20's and they look great! No rubbing!
I have a set of Cooper snows, 275/60R20, and I understand the rim with issues, but with a 33.08" dia. will they fit? I will be lifting the front about 2" I'd try them on the truck, but the build date isnt untill November, and if you dont get snows around here now, your out of luck for the season.
Did you ever get around to installing the 2" lift (front) and throwing on the 275/60's? This would answer my question if I can get away with the 60 series instead of the 55. Thanks! :boink:
ThirdToy; My final set-up is 2/3 Daystay spacer lift, 265/75/17 BFG's, and for the winter Cooper Discoverer M+S 275/75/17 (with Spidertrax due to rim design) I had some rubbing on full right lock at the front left wheel, cured with a sharp knife and two sheet metal screws to reposition the fender liner.
I'll post pics in the next while, snows go on next week.
cheers
After reading this thread I'm giving Thanks that my head has not yet exploded :cry2:
To all those who installed tires such as Nitto 275/55/20 which are rated for 7.5" on the 7" Limited wheels, are you guys still alive? If so, please post updated reviews. How have you used your truck - pavement , off road, etc...? Any issues?
Only been a few weeks but yup alive and well. Have driven over 1000 miles and tires have performed flawlessly, have had zero issues. Have NOT been offroad.
Hi - do you experience any rubbing? How's the gas millage with these new tires? and lastly - any better or worse street handling?
just put a set of 275/55/R20' bfg rugged terrains on my 2010 limited and they are AWESOME...completely transform the look of the runner from the old pizza cutters that came on it!! picked them up at discount tire..
Rubbing? Do you have a lift?
no rubbing whatsoever and i do not have a lift!!! They look awesome and ride great!!
just put a set of 275/55/R20'...they are AWESOME...completely transform the look of the runner from the old pizza cutters that came on it!!
Bump
I purchased some le 20"s for my taco and want to upgrade tire size and have a couple of questions for those running 275s
1. How is mpg now that you are running wider tire
2. Any body try the cooper Zion ltz
