20 inch wheels on LIMITED
4th Gen Limited Wheels on a 5th Gen?
I did a search, but did not find anyone who has put the latest 4th Gen wheels on a 5th Gen. I always liked that wheel and I think it would look good on my 2010 limited. Any thoughts?
So I've read through this entire thread and I still don't know if I know what the largest size tire is that can be put on the 20" Limited wheels keeping everything else stock (no lift). Can anyone say for certain what the largest size tire is that can be used within the recommended limits of the 7" width rim? Thanks.
I have 285/50-20 Michelin Latitudes mounted on mine. I'm very happy with the improvement in ride, handling and looks.
There's an issue with your post on the forum, it says "content protected by owner" with no actual image. I saw the pics at your online album directly. No head on shot to see the stance from the front or behind! :crybaby:
These were ok'ed by the dealer? I really don't see how. Based on my research a 265 tire needs at least a 7.5" rim width. What am I missing here?
OOPS! Sorry, I think it's fixed now.
I had them installed at my local Discount Tire and they've never steered me wrong in the past. Their site, Tire Plus Sizes - Discount Tire, shows them as a Plus Zero size for our wheels.
I searched all of tirerack.com and found that any 265/xxR20 is looking for a MINIMUM 7.5" rim. I found 1 255/xxR20 where the mimimum rim could be 7": Bridgestone Dueler H/L Alenza 255/55R20. Now personally I would not go with those tires because the sidewall would be even smaller than the stock Yoko's--5.78" (Yoko's) vs. 5.51" (Bridgestone). Beyond that, the Yokohama's simply look like a better tire from an all-season tread design standpoint and were specially designed for the 5th gen 4Runner Limited. Bottom line though, Toyota made a poor design decision IMO going with 20" x 7" wheels--ridiculous. :ybrick:
So let me get this straight, Toyota chose a rim that only has 2 tire options in the entire country that actually fit the rim correctly? Please tell me I'm mis-understanding.
I have a set of Cooper snows, 275/60R20, and I understand the rim with issues, but with a 33.08" dia. will they fit? I will be lifting the front about 2" I'd try them on the truck, but the build date isnt untill November, and if you dont get snows around here now, your out of luck for the season.
Response from Tire Rack about putting 275's on stock limited rims, any comments ?
Below is the response I got from Tire Rack about putting 275/55/20's on stock limited wheels, any comments ? I realy want to put on the 275's but want to be safe as well.
Thanks,
George
You'd be squeezing the tire down to a narrower section width than their designed to work with.
You could mount them, but you'd run in to shops not wanting to take the liability for this mounting. You also have a tire that is ready to debead it self as soon as the tire carcass has enough flex to allow it , for instance as the tire looses pressure it may try and leave the wheel.
. When you squeeze down on a wheel you also increase the wandering nature or tram lining of a tire -= and possibly even addional vibration, fro the tire's tread not making even contact with the pavement.
I'd stick with the 245 stock width, or pick a wider wheel to get into 275's. I'd also be concerned about 7" wide wheels being load rated for the truck, thats normally a passenger car width.
Thanks,
George
pay attention to the comment about the 7" wide wheel being for a passenger car. good job toyota...:jaw drop:
buy better rims to be safe
saw this on tirerack...thought it was interesting. be nice if toyota talked about this...
"some vehicle manufacturers and tire companies have permitted rim widths that are not within the tire's original approved rim width range. For example: BMW has combined 235/40R17 sized tires on 17x7.5" rims (which are 0.5" less than the narrowest 8.0" wide rim listed for the size) on certain M3 models; and Chevrolet has combined P255/50R16 sized tires on optional 16x9.5" rims (which are 0.5" wider than the 9.0" wide rim now listed for the size) on certain Corvette models. While these applications have received the approval of the vehicle and tire manufacturers, staying within the approved rim width range helps assure that the tire's internal stresses are within its design parameters.
Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit. The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10"."
I have a 2011 Limited that has the 2" leveling on the front. I am in the market for some new shoes and would love to put on 275/60 as opposed to the 275/55. My issue is that I do not want rubbing. I don't mind trimming a little up front, but don't want to go nuts with it. I believe I remember Gary (harper7) saying something about trimming without making it look like you trimmed. Anyone who has done this please help! Thanks guys! :thanks:
I know this is off topic, but why do dealers feel they need to brand this much!!! :uzi: A license plate frame is enough. This dealership had to put their name on an adhesive plate and tow hitch. You should charge them for advertising
Free Advertisement so why would they not do it :)
Its up to the customer to have them removed. I inform the dealer for every new car that I want not one sticker on it. Once they 'forgot' and I guess they figured I would let it go - but I told the sales guy to get me a cup of coffee while they removed them.
Does anyone have any experience with this? :hungry:
I can tell you in a week or so....I have a limited that I'm about to put a daystar lift on and run 275/60 20 Terra Grapplers. I have the lift and tires, but no time to install.
Great! Is the Daystar lift for the front, or the rear as well? Please take pictures and let me know if there is any rubbing! :jump:
Move the front inner fender liners as far forward as possible. You'll get an extra 3/4 -1" more tire clearance.
The way to do it is remove the 2 or 3 screws on the bottom of the front of the front fender where the liner is sandwiched in between the fender and the brackets. Physically push the liner as far forward as possible, dremel,cut or drill new holes in the liner and put the screws back in to hold it forward. Just in the liner!You can do one at a time really to help you hold it forward.
I slotted my holes with an exacto knife but if I had to do it over again I would just put new holes in with a dremel and small rotary ball.If you use a drill ,watch that you dont drill up thru the nuts .
I had pics on here somewhere of it but can't find them. It would be nice if somebody did a DIY on this with pics for the Mods sticky if they do it.
Then, if you get it aligned by somebody that knows what they are doing with caster adjustments, have them move the front wheel as far forward as possible within specs.You'll have the room to move the wheels forward since you moved the liner forward and you shouldn't rub in front or back then with a 33 inch or smaller tire and close to stock backspace/wheel width.If lifted,you'll get better caster specs and more down travel with aftermarket UCA's .The corrected angle of the ball joint on an aftermarket UCA nets you at least 1-2 more inches of down travel.The upper ball joint should be the limiting factor in down travel on a IFS like the 4Runners.
TE owners will still have to trim the front rubber mud flap a little though, at least I did as that inside hump sticks out. It's rubber and I just cut the hump out with an exacto knife.You'll know what I mean when you look at it.
Philthyphilthy
