2000 Limited - Daytime running lights got to go
T4R_Finally
Okay, I'm all for DTRL's but only if they can be switched off when it's obvious they are overkill. I did a search and saw someone mention that they can be deactivated on 2000 models by unplugging something on the fender by the battery. I looked down there and I see something that seems to be covered by a black plastic vented box and then there is a grey plug down beside that. Are either of these what I need to unplug to disable the DTRL's?
photo-3.jpg~original
yeah just unplug the gray connector no need to remove the whole module but thats up to you. i just masked the ends off with a couple layers of duct tape.
What's the secret to getting this connector unplugged. Squeeze one end, or pry something open? Tight squeeze and I don't want to break anything. Guess I could take the battery out first.
willsmith2473
