2001 Drive Shaft problem
wakkoguy
Recently my 2001 4runner was making metal clanking sounds for about a day underneath. I couldn't see anything when I checked. The next day (and since then) the truck has been vibrating everytime I accelerate and when I reach about 50mph the car makes a really loud humming sound. So loud that I have to slow down in order to be able to bear it. I took it to the dealer and they said it was the drive shaft and that it would cost me $660. I am looking for a second opinion but my question is that is it ok to drive my 4runner right now? or is it unsafe?
I would not drive it, if the dealer says it's the driveshaft chances are elsewhere they'll say it's a driveshaft too. Should something break, your fuel lines, brake lines, exhaust system and fuel tank are in the line of fire.
What did they say that was wrong with the driveshaft? Really, the only things that can go wrong with the drive shaft are:
1) Twists in half
2) Bad u-joints
3) Throws a weight and becomes out of balance
None of these should cost $600. It only takes a few minutes to install a driveshaft and you can have a DS custom built for ~$300.
Fixes for the above issues are:
1) buy a new DS
2) pull DS and install new u-joints, rebalance
3) pull DS and grease current u-joint/install new u-joints, rebalance
Isn't there a driveshaft bearing on this year 4R? It's a standard lube part on servicing and I think most drivetrain vibes are caused by this bearing going bad.
Someone correct me?
Philthyphilthy
