2002 4Runner Horn won't stop honking
emrooz2809
If anybody can help me out. I went to my car to get something out. I used my remote alarm key to unlock the doors as well undo the alarm. As soon as I did that the horn went off and would not stop even when I tried to turn off the alarm on from remote key. Finally, I just removed the horn fuse to turn it off. Does anybody know what is wrong with it or a way to fix it?
could be a number of things. wiring, condensation, faulty switch..........if you replace the fuse does the problem fix itself?
Check the horn Relay, it could be stuck closed. It is located under the hood, in the black fuse box behind the battery.
That was a common problem to some of my friends, the other was the car alarm won't stop. It's because of faulty wirings and switches. You may look for some aftermarket Toyota truck parts to some store and replace those. That may lead to discharge of your car battery.
