2002 Not starting but turns over fine with new battery
Did you check for spark?
Have you pulled the plugs to look at their condition? AKA dry or fuel soaked……..
If you sprayed starter fluid and it didn’t run then either you have no spark or the plugs are fouled.
When spraying the starter fluid, it almost sounded like it was "trying". Very briefly, but it did that a few times. I'm just gonna give it a full tune-up at this point I think?
Tuneups are a wonderful thing. Especially if you’ve never replaced spark plugs.
The 97 limited I bought with 125k miles still had the factory plugs. The gap erosion was so bad I couldn’t believe there were no missfire codes.
My 2002 sr5 doesnt have a smart key? do you have the LX model? didnt think 3rd gen have that. maybe LX models do?
I agree is sounds like a security issue. since you have no codes and it ran just fine before I doubt anything is going on. The spray should get a few fires if they are sparking.
The fuel pump is easy to hear just get in the car first and turn the key to on, you canhear the fuel pump prime, If your worried pop the fuel door and undo the car and have someone listen there. you will hear it.
Like others have said if you need proof if its sparking or not, pull a plug and keep it plugged into the coil and hold it to the ground terminal or any metal on the engine. crank the key you will see spark or not.
I have a cheapo spark plug tester Amazon.com
7ron
