2003 Acura MDX
Link:
Another '03 MDX Review
2003 Acura MDX
Type: Front-engine, four-wheel drive, seven-passenger luxury sport utility vehicle
Price1 : Base, $35,700; as tested, $42,500
Engine: 3.5-liter V-6; 260-hp; 250 lb-ft torque
EPA fuel economy: 17 mpg city/23 mpg highway
Key competitors: BMW X5, GMC Envoy, Infiniti FX35, Jeep Grand Cherokee, Lexus RX 330, Lincoln Aviator, Mercedes-Benz ML 320, Mitsubishi Montero, Nissan Murano, Toyota Highlander, Volvo XC90
12-month insurance cost2 : $1,503
Where built: Alliston, Ontario
1 Includes $500 destination charge. 2 Estimated by AAA Michigan. Rates may vary depending on coverage and driving record.
Paul's vehicle rating: 4
Likes: Improvement in horsepower over previous model. Superior convenience features, including navigation system with rearview camera, and DVD entertainment system. Smooth new five-speed automatic transmission. One of the best riding crossovers in the segment. Corrects shortcomings on competitors such as RX 330.
Dislikes: Our test vehicle didn't like to start. Middle-of-the-road fuel economy. Not as sexy as an Infiniti FX. Carpet coming loose from center console.
Anita's vehicle rating: 4
Likes: Pleasant, roomy cabin for seven passengers. Standard all-wheel drive. Improved handling. Flat-folding third-row seat. Four-year/50,000-mile limited warranty with roadside assistance and concierge service. Great value in an expensive segment.
Dislikes: Styling is bland and minivan-ish. Visibility compromised by thick rear pillars. Wind and tire noise at highway speeds. Ride is a little rough. No side air bags or curtains for rear passengers.
Here is a post from ACURAMDX.ORG/FORUMS:
http://acuramdx.org/forums/showthread.php?threadid=11978
MDX Transmission Failures
I was wandering around the NHTSA web site tonight and found the results of their Defect Investigation into Honda 3 gear transmission failures. It was listed under 2003 Acura 3.2TL at http://www-odi.nhtsa.dot.gov/cars/p...ect/results.cfm . There were 3 documents listed – be careful, the 2nd one is 15Mb in size.
Near the end of the 15Mb file there was some data about 2002 MDX failures. It showed 8 failures as of Sept 02, with an increasing trend since Apr 02. (There are >1000 failures in CL’s and TL’s)There is tons of Honda technical info in the document. To summarize the problem, the 3 gear clutch pack overheats (>300C in clutch) and wears excessively which causes shifting problems or engine flare-up. Debris can also clog the oil strainers and in some cases cause the tranny to suddenly shift from 5th to 2nd gear due to low hydraulic pressures. The strainers also fail.
The root causes appear to be:
- Poor clutch plate finish (US sourced plates were worse than Japan.)
- Excessive heat generation during 2-3 and 3-2 shifts
- inadequate lube flows to clutch
The fixes were to change plate design (implemented Apr02) and revise ECU computer shift programs (May 02).
There was also a note on one graph which stated: “Currently MQ has “Direct Call-in” for all ‘02M MDX ATM’s suspect for 3rd Clutch Failure to do quick analysis”.
The NHTSA closed the investigation in March 2003 and based on Honda’s information, concluded there is no safety defect.
Not too good for Honda/Acura! :(
P.S.: Here's a whole subforum dedicated to TRANSMISSION problems:
http://www.acuramdx.org/forums/foru...stpost&sortorder=desc&daysprune=1000&x=16&y=9
Link:
CanadianDriver.com Review of '03 MDX
Verdict
Powerful, comfortable and not at all like a truck, the 2003 Acura MDX is a 7-passenger all-weather vehicle with decent handling, ride and acceleration and plenty of standard features for a price under $50,000. [Canadian money, not US dollars.]
Popular Acura MDX Luxury SUV Adds Sportier Styling, Side Curtain Airbags And Even More Horsepower for 2004
The 2004 Acura MDX luxury sport utility vehicle receives updated styling, new safety systems, additional horsepower and an assortment of new features. The new 2004 MDX sports redesigned front and rear fascias, redesigned alloy wheels, a new Side Curtain Airbag system that helps to protect occupants in all three rows, and interior upgrades including enhanced interior lighting and, on models with the available Touring Package, power-adjustable driver's lumbar support.
"The public knows a great thing when it sees it and the MDX has been one of the most sought after luxury SUVS on the market since it was introduced in 2001," said Dick Colliver, executive vice president, auto sales. "With the numerous changes we've made to the 2004 model, it should be hotter than ever."
The 2004 MDX features sportier styling designed to more accurately reflect the strength of its high performance powertrain. The signature Acura family grille, which now sports a sophisticated satin chrome finish, serves as the centerpiece for a new, more tapered front fascia. A redesigned headlight treatment features a leaner, more angular design and new projection-type headlights that enhance illumination while accenting the new styling. The front bumper has been redesigned with a new, more integrated chin spoiler that accents the sporty styling and moves air smoothly to the sides of the car for increased aerodynamics. The rear fascia has been updated as well with a new, more sophisticated taillight treatment, and dual exhaust tips. Two new exterior colors, Aspen Pearl White and Burnished Bronze Metallic join the MDX palette for 2004.
The 2004 MDX's 3.5 liter, 24-valve, all-aluminum, VTEC V-6 engine benefits from a new, dual exhaust system that boosts horsepower from 260 to 265 and torque from 250 lbs-ft to 253 lbs-ft. This exhaust system utilizes two close-coupled primary catalytic converters, a secondary underfloor catalytic converter, and larger diameter exhaust pipes. In addition to adding horsepower, the new exhaust system helps the MDX meet stringent ULEV-2 emissions standards. With estimated city/highway ratings of 17 mpg city/23 mpg highway, the MDX delivers better combined fuel economy than most of its luxury competitors.
The MDX features a compact 5-speed automatic transmission with components engineered to provide the durability needed for on-road, off-road and towing use. A wide-ratio design affords a first gear with extra pulling power to start heavy loads and a high top gear for quiet highway cruising. This 4-shaft gearbox utilizes a unique shaft layout that not only reduces size, but also trims gear noise, clutch drag and hydraulic friction.
The 2004 MDX employs a drive-by-wire throttle system that evolved from the NSX supercar. This innovative system eliminates the need for a mechanical connection between the accelerator pedal and the engine, and modulates the throttle during transmission shifts for improved smoothness. It also allows for throttle control to be seamlessly incorporated into the MDX's VSA logic and directs the vehicle's cruise control function.
The 2004 MDX utilizes a unique VTM-4 four-wheel drive system designed to enhance traction on low friction surfaces. Unlike conventional automatic 4WD systems, which react only to wheel slippage, VTM-4 proactively apportions torque from the front to the rear wheels before wheel slippage can occur. When cruising, the system automatically reverts to front-wheel drive for improved fuel economy.
In addition to ample power, the MDX delivers sport sedan-like handling and a smooth, compliant ride. It features a 4-wheel fully independent suspension, 4-wheel disc brakes with 4-channel ABS, dual piston calipers in the front, standard 17-inch alloy wheels and specially designed P235/65R-17 all-season tires to provide stability and responsiveness. Front and rear stabilizer bars, a wide track and a low center of gravity give the MDX predictable cornering response and help maximize cornering capabilities.
Handling is further enhanced through the application of a standard Vehicle Stability Assist (VSA) system that works in concert with the VTM-4 and drive-by-wire throttle systems to provide enhanced control during acceleration, braking and cornering. This 4-channel system orchestrates the throttle and each of the vehicle's four disc brakes to seamlessly integrate traction control, Anti-lock braking, and stability enhancement for increased driver control during acceleration, braking and cornering.
The MDX's interior emphasizes the vehicle's versatile yet refined character with standard-setting levels of luxury and functionality. Three uniquely transformable rows of seats allow the MDX to comfortably seat up to seven passengers. A convenient walk-in feature provided at the right (curb) side of MDX's second-row seat slides the whole second seat forward with the touch of a lever. This feature has been improved for 2004 by extending forward travel 40 percent, making entry and egress to the third row even simpler. Second and third row seats split and fold flat into the floor providing 82 cubic feet of cargo room. Even with all three rows in use, the MDX still offers 14.8 cubic feet of cargo room behind the third row seats.
For 2004, a variety of enhancements have been made to the MDX interior including the addition of brushed metal-look trim on the instrument panel, ambient foot lights, and welcome illumination. A new, Side Curtain Airbag system has been applied to help reduce injury to occupants in all three rows of seats during a sufficient side-impact collision. It deploys from a module in the roof in the event of a sufficient side impact, providing an important and significant level of head protection in the window area. This system also includes a series of rollover sensors designed to trigger the system in the unlikely event of a rollover. Should the MDX begin to tip, the rollover sensors monitor the rate of roll and deploy the side curtain airbags accordingly.
The MDX also features dual-stage, dual-threshold driver's and front passenger front airbags. The driver's airbag adjusts deployment force to one of two rates according to input from sensors which monitor the severity of the impact, seatbelt usage and the position of the driver's seat. The front passenger airbag's deployment takes into account the severity of the crash, seatbelt usage and the passenger's weight. The MDX also offers driver's and front passenger's side airbags with occupant position sensors in the passenger's seat; and the LATCH (Lower Anchors and Tethers for Children) system on the second row of outboard seats to simplify child seat attachment.
New for 2004 is a direct Tire Pressure Monitoring System that uses sensors in the valve stem of each wheel to alert the driver when tire pressure drops significantly below the recommended level. If the system detects that tire pressure is low (32 psi is recommended), the low pressure indicator notifies the driver, while a schematic of the vehicle located in the center meter housing the speedometer indicates which tire or tires require air.
While the MDX is already one of the most comprehensively equipped vehicles in its class, an optional Touring Package adds a variety of premium features. These features include a roof rack; exclusive alloy wheels (redesigned for 2004); an upgraded, eight speaker Acura/Bose Music System with 6-disc, in-dash CD changer; two-position memory for the driver's eat and sideview mirrors, and a front passenger's 8-way power seat. For 2004, the 8-way power-adjustable driver's seat now features power-adjustable lumbar support. The Acura/Bose Music System receives a more powerful 225 amplifier and revised speaker tuning for superior sound reproduction.
The Acura Navigation System with Voice Recognition is available as a factory-installed option on models equipped with the Touring Package. This state-of-the-art
navigation system includes a menu of 217 voice commands, a comprehensive destination guide with over 7 million points of interest, turn-by-turn guidance and coverage of virtually every road in the continental United States. For convenience and safety, the system also includes a rearview camera incorporated into the tailgate, which transmits a rearview picture to the navigation screen when the MDX is in reverse gear.
The Acura DVD Entertainment System is also available as an option on Touring Package-equipped models. The 7-inch LCD screen is mounted to the headliner, just behind the front seats for use by rear seat passengers. The DVD player mounts below the standard audio system and plays over the MDX's sound system or through a pair of cordless infrared headphones. The system can be controlled either by using the MDX's audio controls or from the rear seats through the use of a remote control or the screen's control panel.
Well! I say it's about time the MDX interior got upgraded! The fake wood doesn't look as bad anymore. The exterior is starting to look more like a Nissan Pathfinder (not the Armada though!!) in my opinion. Still some proportions look a little weird. Overall a good job with redesign!!
Good time to play catch-up to Volvo with airbags for all 3 rows of seating and to Lexus with clear white tail lamps. :)
I love the MDX's, I think they are sweet looking. I hate the new 4Runners, the 3rd gen was the last style to look good. 2nd gen is where it's at. :)
Personally, i hate the look of the MDX. It looks too minivan-like. If you look at the rear, then you can see all the suspension parts. The underbody is a joke...things hang down so low that it can pick up roadkill if you're not careful!:duh:
For a "luxury" SUV, it's interior is surprisingly very bland. Hard plastics everywhere. Nothing stands out.
But i must admit that it's navigation system is good.
Test Drive: 2004 Acura MDX
by Grant Yoxon
Last year, Acura gave its MDX midsize luxury sport-utility some significant mechanical improvements.
Among them: a new five-speed automatic transmission, vehicle stability assist, an electronic throttle, an improved all-wheel-drive system and substantial chassis reinforcement.
Horsepower from the 3.5 V-6 engine rose to 260 from 240, and torque to 250 pound-feet from 242, thanks to new cylinder heads, a shorter intake manifold and a retooled exhaust system that increased flow by 40 per cent.
Apparently, though, that 2003 MDX was an unfinished project.
Now Acura has turned its attention to features and appearance. For 2004, the MDX gets a styling update, some interior revisions, additional safety features and an optional "tech package" offering a navigation system, DVD entertainment system and a rearview backup camera.
And with a new dual exhaust system, power is up again, to 265 h.p. and 253 lb.-ft. of torque.
The exhaust outlets accent new taillights and the revised rear bumper and trim. New headlights, grille, bumper, foglights and skidplate and a new 17-inch wheel design complete the styling changes. Overall, they give the MDX a cleaner, less cluttered look, particularly up front.
Interior enhancements include blue ambient lighting in a new overhead console as well as in the footwells. The leather upholstery on the front and second-row seats has been changed (the third-row seat has "leather-look" upholstery). A power lumbar adjuster has been added to the driver's seat, which has a two-position memory control.
Both driver and passenger seat are eight-way power-adjustable (up and down, front and back, tilt and seatback recline).
Oddly, the driver's seat does not retain its setting once the vehicle is turned off and the doors are locked. It reverts to a low, rear-most position. This eases access, but requires the driver to readjust the seat with either the memory buttons or the seat controls before setting off again.
Still, the seats proved to be a high point on several long journeys, providing good support for both the back and legs and easily adjusting to a comfortable driving position.
The MDX has plenty of room for both passengers and cargo. It's wider than many of its competitors, 100 mm (4.3 inches) broader than the Lexus RX 330, for example, and 83 mm (3.2 in.) wider than BMW's X5. My three teenagers never complained about sitting in the MDX's second-row seat.
Cargo space behind that seat is an enormous 1,405 litres (49.6 cu. ft.), when the third-row seat is folded. Or, with both rows of seats folded to form a level platform, there's 2,308 litres (81.4 cu. ft.) of space.
Even with the third-row seat in place, there's still 419 litres (14.8 cu. ft.), more than the trunk space in some midsize passenger cars.
The third-row seat is actually two buckets that fold independently, giving you some flexibility, but the seats themselves are designed for occasional use and certainly for no one bigger than a child.
Riding in an MDX means travelling in comfort. Along with the usual powered features are an audio system with cassette, six-disc CD changer, eight speakers and steering wheel-mounted controls; automatic climate control with front and rear controls; trip computer with compass and outside temperature readout; speed- and rain-sensing windshield wipers; and a sunroof.
While the $5,300 tech package increases the content considerably, the MDX has not kept up with some competitors. For example, its CD changer is mounted under the driver's seat, not in the dash. The steering wheel tilts but doesn't telescope. Only the driver's window is auto-up and -down. The backup camera is a useful aid, but no other backup or parking warning system is available.
The rear DVD system, however, is a blessing on long trips. The inclusion of two sets of wireless headphones means front and rear passengers can choose their own entertainment.
The navigation system provided accurate information about streets and points of interest in our community, but like many of these systems, learning how to use it properly requires some study of the manual. The system can be operated with voice commands in French and English.
One area where the MDX has kept pace is safety. For 2004, Acura has added a tire-pressure monitoring system and standard side-curtain air bags with rollover sensors to an already extensive list of standard passive safety features. The 2003 MDX received four out of five stars in front-impact testing by U.S. regulators. The 2004 model has not yet been tested for front impact, but did receive five stars in side-impact tests.
Active safety features -- those that will help keep you out of trouble -- include vehicle stability assist (VSA) with traction control, four-wheel antilock brakes and, of course, all-wheel drive.
If the MDX begins to go out of control, VSA automatically brakes individual wheels and reduces the throttle to correct directional stability. The system will engage only if the vehicle is in danger of spinning out.
Acura's all-wheel-drive system, called Variable Torque Management 4-wheel drive (VTM-4), operates in front-drive for dry-pavement cruising conditions and engages AWD only when there's a need to improve mobility, stability or manoeuvrability. This system anticipates the need for all-wheel-drive and engages the rear wheels before slippage begins.
There is no low range -- the MDX is designed for medium-duty off-road use -- but it can be locked in four-wheel-drive to help it get out of a slippery hole or, more commonly, a snowbank.
We had ideal conditions -- lots of wet snow -- to test the AWD system and found the MDX to be very stable, even when the driver had a heavier foot than conditions warranted. The torque transfer was immediate and noticeable as the MDX fought for traction, but rarely did we notice the traction control system come into play. Our tester's Michelin Pilot Alpin winter tires certainly helped as well. Stopping was just as solid, the ABS bringing us to a halt without any side-slip.
With its wide stance, fully independent multilink suspension and 17-inch tires, the MDX feels stable, despite its height. The body is tight, and you sense the MDX is strongly built.
The V-6 has plenty of punch for accelerating onto the freeway, overtaking slower traffic or simply moving the 2,046-kg MDX briskly from a stoplight. It's also quiet, purring at 1,700 r.p.m. at 100 km/h. That, and little noise from wind or tires, make the cabin a tranquil place.
With the addition of a $1,149 towing package, the MDX can tow trailers up to 1,588 kg (3,500 lb.) or boats up to 2,041 kg (4,500 lb.).
Fuel consumption is good for a vehicle this heavy, but the MDX is no miser. It requires premium fuel.
Despite its relative youth, the MDX could have quickly fallen from contention in the midsize luxury SUV class. Competition is severe, with new or revised models coming from Cadillac Lincoln, Mercedes-Benz, BMW, Lexus, Infiniti and Volkswagen since the MDX's introduction in 2001.
But Acura has managed to keep the MDX current, first with a thorough mechanical upgrade in 2003 and now with freshened styling, improved safety and new, optional comfort and convenience features.
MDX?
Well I have 4 friends with this car, and I thought about this before 4Runner, however it is SINGLE OVERHEAD CAM, and priceyer!!! The horsepower is higher, but the torque is lower than the V6 4.0 in 4Runner
3rd row bench in the Highlander is a lot better than on the MDX/Pilot... can't even latch the tip-forward 2nd row seat coz my knees get in the way...
Crookedcat
