2004 4Runner SR5 Brake Modulation/Pulsing
letsridegg
Hello - I'm new to this forum and I'm hoping someone can point to any info on the brake issue I'm having. The issue is with applying the brakes, and the erratic modulation I feel when pressing the brakes at speeds under 40mph. I've sensed the pulsing/irregular modulation above these speeds, but not as bad when slowing from around 40mph. For example, when coming to a stop, the brakes seem to bite then ease off, then bite again. I had the rotors turned, which seemed to resolve the issue, but a few weeks later, the issue is back. Any info is appreciated!
Sounds like a rotor issue to me. Why not buy new rotors and call it a day? BTW, it's always a good idea to properly bed the pads/rotors whenever you install new brake parts or even after you cut the old rotors. Proper bedding should eliminate any potential braking system problems.
I agree with Jed, turning rotors will only allow them to warp quicker next time. Buy new ones with good thickness. Also must change pads when you do this, ****ty pads will cause ****ty rotors.
The first step in solving a problem is to understand the problem.
Turning rotors will have almost absolutely no effect on "warp" simply because brake rotors (almost) never warp in the first place.
Don't believe me?
Read the references quoted here ...
33097d1284799804-solved-my-3rd-generation-4runner-severe-brake-pedal-pulsation-highway-speeds-brake_friction_material_deposited_on_rotor.jpg
