N nicheel8 Member Jun 22, 2024 #1 Can anyone recommend a stronger AC blower motor. The air is cold, just need something stronger for the Arizona heat.
xtremewlr Member Jun 22, 2024 #2 You don't need a stronger blower. Try changing the cabin air filter. I bet it's causing the issue.
S SocalSam Member Jun 23, 2024 #4 Mine came with an aftermarket blower. Flow was acceptable. I replaced it with a used OEM and the flow improved. Get OEM.
