2004 Limited V6 Fob programming.. madness!?
roguzdon
Hey all-
Sorry for my first post being a cry for help ;-)
So I just for a 2004 4Runner Limited V6-
It was a deal... so there are a few issues here and there.. The only big one being that it only came with a Valet key. So! I got bent over at the dealer to get a Master key cut and the computer reprogrammed but that's how it goes.
The issue is the Keyless Entry. I grabbed a few fobs on amazon. Master key in hand, no problems right?
Basically I just cannot get it into programming mode. I've followed these directions to a T..
I've checked the fuses, disconnected and reconnected the battery but for the life of me.. just cant get it into programming mode. I cant rule out human error cause we're all a little dumb sometimes.. but I think im doing everything right.
Any suggestions, advice, things to try before I call up a locksmith?
Thanks!
As for the 4Runner. It's totally rad... Honestly I'm not sure if I'll ever buy a different type of car again.
Some years back I had a 97 Corolla Touring Wagon when I was living in Japan. The 4Runner granted a lot taller and heavier... drives just like that car. Its crazy familiar. Brings me back!!
Hey all-
Thanks!
hello,
Your T4R is perfectly okay. You are just not going through the procedure fluidly enough. I just got a T4R too, a V8 and didn't come with a keyless fob. I got a fob from Ebay and I actually went through hell before I could program it.
However, with the benefit of hindsight, I discovered it is actually because I was not fluid with the movements. please click on the link below and you will be cool.
http://www.justanswer.com/toyota/4yah4-toyota-solara-se-went-toyota-dealer-check.html
I just used the exact same instructions to program key fobs on my 04 limited, worked perfect. Just go through it smoothly and it should work. I will say I felt pretty dumb opening and closing the door in my driveway. Lol
