2005 4runner Lifts
joeyz
A while ago I had a Toytec 3" Lift installed. It's time to replace the shocks and I purchased Bilstein 5100 adjustable shocks & struts. I want to set the Snap Ring on the Strut to the 2" mark to make the front & back of my truck level. Right now the front end has that rake look (not bad) a little lower than the rear. I want to check that the Frame is level right now before I install the Struts with the Snap Rings set at 2". I hope this will work without having to do additional work because of the extra 2" Lift in the front. I'm sure I'll have to adjust the Diff/Drop bolt to accommodate the Lift and I hope that's all... Any suggestions or experiences with this? Thanks
BillM777
