2005 4Runner V8 LTD 310K KM/ 192K MILES TORONTO CANADA
Bernardchan96
IIBglD6
2005 4Runner V8 310,000km
Very well kept & Maintained with receipts for all part purchases,
Oil Changes every 6000Km
Front
-06+ Headlight Swap
-Volant CAI
-Secondary Air Injection Bypass
-Timing belt & Water pump done at 290,000km
-Thermostat &Thermostat Seal, Serpentine Belt, Belt tensioner, Idler Pulley
-Radiator Lower Upper Hoses
-PCV Valve Replaced
-Neutral Safety Switch & Starter Replaced at 280,000km
-FALKEN AT3/W Tires placed on March 2019
-2.5" Front Lift with Dobinsons Nitro Suspension
-JBA High Caster Upper Control Arms
-Poly Performance Taco Tabs
-OEM Lower control arms powdercoated w Whiteline bushings & new senkei 555 Lower Ball joint
-Replaced front sway bar end link & Mounting bushings
-New outer Tie roads
-New Brake Dust shield & Driver, passenger wheel bearings replaced at 290,000
-Rear Dobinsons Nitro 2" Lift
-New Rear Rotors & Pads at 290,000
-Proforged Extended rear sway bar links With replaced Rear sway bar,
-Magna Flow muffler & Exhaust Tip
-LED Swapped Cluster
-Sony AX100 Headunit.
-RA Motorsports Front Skid plate
-Rear Brake lines Replaced
-New Windshield replaced June 2020
Couple more things i forgot to list,
Had some Rust prior, i wire wheeled the whole frame & applied POR -15 now its yearly coated with Krown
Transmission fluid changed 280k
-Exhaust replaced at 271Km
-Front Brakes 255k Km
-CV Passenger & Drivers boots replaced & Re-greased Aug 2019
-Spark Plugs replaced Sept 2018
-power Steering return hoses replaced Oct 2018
-transmission Return hoses replaced 2020
-Just krown rust protection in Sept 2021
Looking for offers, not in a rush to sell, been looking at something a bit more fuel efficient. Has been my Go getter for my canoeing trips, but my longer trips with this car means, bigger fuel costs.
I also have a clean Carfax i pulled i can show
Selling AS IS, 12.5k
PobLyMu
Imgur: The magic of the Internet
Ambrose67
