2005 4Runner valve noise
bobdod04
Hello all, I hope to soon be a 4Runner owner and I am working on a deal for a 2005 model now. I went to look and drive the truck yesterday and might be making a deal today. The truck was in decent enough shape, but when I opened the hood, the engine was emitting a clicking noise from the top. I am guessing its valves being noisy? I've heard that its common on these engines, but I thought I'd ask anyway. Is this something to be warry off? should I walk from this deal? the truck has 105K and I can get it for $10.5K.
Also as a side question, I was looking in the cubbies in the back compartment on the sides of the truck. One had a jack and some tools (driver's side), but the one on the passenger side was empty. What should be in there?
One final question: I would have made the deal yesterday, but just as I was about done checking out the truck, I opened the sunroof and when I went to close it it wouldn't close (would close a small part of the way than make a loud click and open back up). I figure its off the track or something like that. I told them I wouldn't buy the truck without it being fixed or receiving a discount for the cost of the repair. How common of a problem is this? Whats the cost to have it fixed?
Thanks for your help in advance!
I wouldn't worry about the "Valve noise". Both of my 4th gens sound that way with no issues. 116k on the 04.
Passenger side empty compartment is for the Subwoofer for the JBL sound system in equiped vehicles. Those without it like my 04, it is just a nice storage compartment.
The sunroof from what I have read is a common problem and my understandling is it can be fixed. Not sure of the cost. Do a search you should find a number of threads about the sunroof issue. I have not had an issue with mine in my 08, granted it only has 49K miles.
Good luck
my 04 (v8) has been making the clicking noise for a long time. at both my 90k and 120k service i asked the mechanics about it, they said they weren't going to fix it because it is not a problem.
well, it was a battle, but in the end I got the truck at the right price. Thanks for the feedback on the valve noise. I've read elsewhere that it is pretty common on these V6 engines and the truck drives fine. Its at the dealer getting the sunroof fixed. They said the wind deflector was broken and they are waiting for parts. The estimate came to $200 so I had the dealer drop a few hundred more off the final price on top of that just to be safe (it was a battle I tell you!). I plan on doing the following once I get it back:
- change oil (what oil do you guys recommend?)
- change all of the gear oil (whats the recommendation here?)
- Have the dealer change the transmission fluid (not sure if I can do this one myself or not)
- possibly change the spark plugs (which ones should I use?) since I am pretty sure its probably due for new ones.
Anything else I am missing?
Sunroof may cost you $1000 or $2000!
Do a search on stuck sunroof, multiple posts on it :flamethrwoer2: don't get burned.
Sunroof was fixed by toyota. Works great and cost under $200. They said the wind deflector was off the track and some part was broken.
Today I did a bunch of shopping and maintenance work.
- Cleaned the throttle body
- Cleaned the MAF
- Replaced spark plugs with Denso plugs
- changed oil in the transfer case
I still need to do the front and rear diff fluids, but I couldn't get them open so waiting for PB blaster to do its thing. Also got a grease gun and will do that as well.
Is it V6 or V8?I have the V6 and have the same type of noise. It could be the VSV valve or something like that. I read a thread on here about it and how to reduce the ticking noise. It has never bothered me and its nothing wrong mechanically so I never bothered to do the fix. Do a search you should be able to find the thread.
Good to hear they fixed the sunroof. Enjoy the 4Runner and the forum.
