2005 Limited RAS Disable
Utah_4runner
Hi all,
I recently converted my RAS to coil springs with the metal tech 4x4 kit. To start I only pulled the air coils and the fuses from the instructions out and didn't have any flashing dash light and just had the green height indicator at N. More recently I pulled out the RAS compressor and gutted the old sensors and everything else that the system used to use... after that I got the dreaded flashing "off" light.
I have searched multiple forums and emailed metal tech and haven't had any luck with finding a solution. I have all of the related fuses removed. I also unplugged every harness under the driver side kick panel (one at a time) and none of them turned off anything with the RAS system. Does anybody know of a fix? Is there a wire I can ground out to fix the issue? If I were to put a wire tap on the harness that the sensors used to plug into would it fix it? I'm open to anything.
Thanks in advance.
AndiGarage
