2006-2009 drl
Xlair
I’m trying to figure out what the correct part number is for the small daytime running light in my 2007. I ordered off rock auto and it’s definitely not the right one and Sylvainias website has me confused as well!
Also if anyone has a recommendation for LED let me know as well. Thanks!
Depends on the MFG and type. What I would consider as the DRL are actually the front signal lamps. That is, if you are referring to the amber side markers up front that are on regardless of headlight setting.
Basically a 1156 Amber (twist lock base) for standard options.
Here are some LED options from box stores:
https://www.napaonline.com/en/p/NDP...urn+Signal+Light+Bulb&keywordInput=light+bulb
https://www.autozone.com/electrical...edt-mini-bulb-1156azevoled/14331_0_37365_2805
The smaller markers below which are technically the DRL according to the manual use a 168 wedge base bulb. LED options would be something with a T10 base. Both readily available at your local auto stores.
H.Sikina
