2006 T4R w/ Xenondepot HID's
I just recently picked up a 2005 SR5 and I was wondering if anyone knows if the lights in the 05 will work with the HID conversion kits that you used from Xenondepot?
yes.... but PLEASE guys, putting HIDs in the stock headlights is going to create WAY TOO MUCH glare for other drivers.
Put HIDs in a modified headlight or projectors.
iFORCE -
Thanks for the reply. Do you have any suggestions on where to look for them? As you can see, I'm new to this board and would appreciate any help I can get. Thanks again.
How was the install on the 3000ks??? Where did you mount the ballasts? Have you had any problems with them at all?? Thanks for your time.
-Gene
Re: Toshiba HIR
ronsta said:
anyone know about these non xenon supposedly brightest halogen bulbs ?
Yeah actually, I had a set in my WRX and they were fantastic. Not sure if you'd notice much difference between them and, say, a GE nighthawk if you add HID lows, but with halogen lows and highs the HIR bulbs are great. I'll be installing a pair even after I put a 4300k kit in my projectors, because I liked them so much.
On a side not, j0, did you use the philips 3000k kit or their "xtreme" kit? I'm kind of torn between the two, as I want the quality of the philips, but with a cost difference like that I might be able to justify skimping on the fogs.
hi guys, i am also wanting to do this mod but wanted to ask you all that installed it a question. How does the setup affect the high beams? Do they still work the same way where both lights will still kick in if needed? I am asking for a 06 model since I know they are different from the previous years....
Your high beams will still work since you are only changing the bulb, I had the PIAA xtremes and they are whiter compared to stock but I am in the middle of converting to HIDs...
Another note on those HIR bulbs, now that I think back to the tech article, they were originally designed as high beams to compliment HID lows (OEM high beam bulb for the Dodge Viper). Just another interesting blurb about them that reinforces my decision to pair them up with the 4300ks I'll be ordering in the near future.
Getting ready to buy my kit, but I noticed something today that is holding me up. Does anyone know how to disable the low beam from coming on when using the daytime "flash-to-pass" feature? Flashing HIDs like that is hard on the ballast.
What's flash to pass?
Gonzaga Lobos
