2006 T4R w/ Xenondepot HID's
The Highs and Lows come on when you flash 2 pass. Flash to pass is when you pull the stick towards you momentarily and then let go. The lights come on for a sec and when you let go, they go off. It's not good to rapidly turn on/off HIDs.
It appears I need to type faster, my point was made about 20 minutes before I could finish making it. Thanks sharp :cool:
ronsta said:
What's flash to pass?
"Flash to pass" refers to when the driver behind a slower moving vehicle flashes their headlights (usually highbeams) so the slower moving moving vehicle will pull over or yield to let faster moving traffic by.
On Toyotas, the turn signal stalk is pulled towards the steering wheel to flash. The highbeam is only on as long as the stalk is pulled, when pushed towards the dash (as long as the low beams are on) it keeps the highbeam on until it's pulled back.
LOL, if only it were as automated as you describe, that the guy in front of you moves when you flash them...
I've never really noticed the lowbeam turning on/off when doing this, I thought it was only the highbeam that flashes & low beams stay on. I guess I'll have to take a look and have a buddy pull the stick back.
The low beam only flashes if the lights aren't on to begin with. When I think about it, I probably don't use flash to pass in daylight often enough to worry, just the occasional "warn oncoming traffic of impending speed trap," but it would be nice to idiot-proof it.
The low beam will come on when the highbeam is on for flashing or in regular use. Unlike headlights that use a dual filament bulb design, i.e. 9003, 9004, or 9007, the low beam does not turn off when the high beam is on.
ronsta,
I should've added "they should" pull over and allow faster vehicles to pass.
ronsta,
I knew what you meant lol.. just giving you a hard time.
So 06/07 owners dont have a problem with flash to pass then rite?
All in good fun... no harm done. :)
What do you mean by "problem"? On my '06 the low beam will come on or stay on whenever the highbeam is on. So for the longevity of HIDs, it would be a problem if you're always behind a slow poke that doesn't know what to do when there's a nice pile of cars riding his/her bumper and you're constantly flashing them with your high beam.
For the same reason, I wish I know how to disable the flashing part of the headlights when the alarm and/or panic is activated. Flashing parking lights will do for me.
The alarm part shouldn't be a problem for me, I'll say something to the shop when I get a DEI installed. Still, I'd like to fix the flash to pass so that it only flashes the high beams.
You should be ok with an aftermarket alarm system, most just flash the parking lights. The factory alarm flashes both the headlights and parking lights.
Fog Light Use
I do not have HIDs, but a common practice for me is to ride people with my low beams, get close enough to them (less than one car lenght) for about 4 seconds, then back off 2 car lenghts and now that I got their attention I flash them by turning on and off my Fog lights.
This tells them that I need to go faster, but I am not going to be an A double Snakes about it by flashing the highs on them.
This works 90% of the time, and when it does not, then I use the HIGH beams and give it to them.
I am not promoting this practice, I am only expressing my technique. :driving:
Re: Fog Light Use
This is a good point. Interesting... what would happen if I'll flush ALL of my lights? :bouncy:
ARB-15-1.jpg~original
Uneek: I tried this the other night, had my lows on and was up against a wall, I flashed my high beams and did not notice the lows turning off/on
Re: Re: Fog Light Use
You'd give the person in front of you a nice tan! :biggrin2:
^ thing of beauty right there. Would that be a pair of 540s and a pair of Rally 4000s?
As for the lows flashing, they won't turn OFF if they're already ON, but they will flash ON with the highs if they are initially OFF.
BTW, if you guys want to see some crazy lighting setups, check out my old home:
NASIOC Lighting Thread
You might want to have someone stand outside and look at the lights as you flash. I originally thought the lowbeams stayed off when I flashed them against my garage door, but because the high and lows are so close together and about a foot away from the garage door, it doesn't appear that the lows are on.
On mine, if the lights are all off and I flash the highbeam the lowbeam will come on with the highbeam. If the lowbeams are on, and I flash the highbeams and the lowbeams will stay on. The fogs will turn off when the highbeams are on, but the lowbeams will stay on. I don't have the foglight anytime/always on mod done. The lighting is stock.
Yes, you got it right. The central ones are PIAA 540 Fog and the outer set is Hella Rallye 4000 Euro Beam.
540 are great for off-roading or driving in traffic in more then 1 vehicle. Very noticeable in a distance. They are also amazing in bad weather when visibility is low.
4000 are awesome lights. They filling up the space between the low and high beams on the road + they also gives two concentrated light beams and lights-up the hi range objects way ahead. So basically they are combine lights from Low/Driving and Pencil Beams.
I like my setup allot. I had 510, 520 on my truck before I came up to this setup and I'm happy with it.
that looks hott i was thinking about doing that and now that ive seen it on your runner its gunna get done thats nice.
Gonzaga Lobos
