2007 4RnR Brakes
ferrisDJB
Need to do a front brake job on a 2007 4RnR. Most likely going to replace the rotors, pads and bleed the system. So, I've seen numerous responses stating OEM brake pads are the best to use. With what I need to do, I usually use RockAuto for parts. What company makes the OEM pads and rotors? The composition of the pads...are they ceramic or a blend of ceramic and copper? Also, apparently there are two sized rotors for an '07, 319mm or 338mm. This is a 2007 Sport V-6.Thanks for any help offered.
OEM pads are semi metallic.
OEM brands are Aisin, Advics, and Sumitomo.
OEM rotors made in US are Brembo.
If you have the larger sport edition or limited 17" wheels then these are the parts to buy:
front brake shim kit 04945-0C030
17" 338mm brake rotors 43512-60151
front brake pads semi-metallic 04465-35290
4 pins 9024006158
pin clip 4774935040
anti rattle center wire 494735050
AndiGarage
