2008 Front Turn Signal Replacement Help
AE1M
Member
I need to change the front left "blinker" bulb. it is in the headlight housing in front of the battery. Any suggestions how the F to get that out? Do I need to pull the battery off? Need some small Japanese hand maybe?
Just grab between thumb and finger and twist.
No need to remove anything else.
Shouldn't be difficult.
A few months ago I replaced mine... I read somewhere to lay under and reach up from the bottom was supposed to be easier. I ignored the advice and bloodied my knuckles for 3 minutes trying to get it from the top, so I then laid on my back, reached up and changed in 5 seconds.
I replaced mine last week. Do the right side first where you have more room to work with. That will give you an idea of how the socket is secured to the housing. Then carefully do the left. I have big hands but I was able to change both. You just have to feel around so you know if it's lined up with the socket then carefully rotate back into the locked position.
Jhunt
