2008 Parasitic Drain issues
simple
Senior Member
A few weeks ago I had an issue that drained my battery. My money was on a radio that was a recent install, and I was partially right. WIth my maestro RR I have a parasitic drain issue with my power antenna. I'm at about 470ma (I'm guessing here...on my multimeter it's on the 10A and the multimeter reads .47). When I unplug the power antenna wire on my JBL system, it drops down 280ma. And I noticed when doing tests on fuses earlier that my fuse amp was and ECU-B both had a draw. So I unplugged my fuse amp and it dropped to .06 or 60ma. I think thats probably where I should be at.
All my interior lights are off. I did do [MENTION=15785]J.A.[/MENTION] 's map light mod and a modified footwell mod with some puddle lights on turn signal mirrors, which I figure was my issue so I disconnected those from the dome and ILE wires on the interior fuse box, and no change at all. So...I'm at a stand still. Any ideas on what could be causing a parasitic drain on my dome fuse?
AndiGarage
