2010 4R damaged sensor,ABS lights reset?
998cc
Hello all. My first post. I ran over a rope on the freeway that wrapped around the front axle right next to the brake plate. All the ABS lights came on, and after removing the rope, I noticed it had strained the ABS sensor wire harness.
I should be able to replace the sensor, but I need to know if the lights will reset after a battery disconnect, or is this a dealer fix like a air bag deployment?
Thanks.
Russ
Owner of many Toyotas since 1983. Never without one; four in the stable now.
Once you replace the wire the lights should clear. Might have to drive a couple miles first but you shouldn't need to have them reset.
2001ATL
