2010 engine miss
Skraler
2010 4runner , 90k .. Slight miss at low rpm under load ... Just replaced spark plugs with new oem plugs no difference .... No check engine ... Trying to avoid dealer . Any suggestions ... Ran fine up until
I would get a mini VCI cable from eBay, which will come with a pirated version of techstream (same thing Toyota dealer uses) to diagnose the problem.
Probably gana buy 1 coil pack and swap 1 out at a time and hope I can find a bad coil pack . Can't use the cable because I do everything from IPhone and got rid of Lap Top a while ago . My man has a Genesis Scanner , might that help ?
Not familiar with that one, but just about any OBD2 scanner will at least give you any stored codes. I would definitely give it a read.
