bump- I just tried to remove mine and couldn't get it off completely. Sail panel off, 2 screws @ handle, and pulled the panel out and up. Something is hanging up by the door handle area. I'm afraid to yank too hard! Anybody know what I'm missing??? Thanks.
^behind the actual door handle there is a small plate that snaps into place. Use a flat head, and carefully pop this piece out and you will then see a phillips screw anxiously awaiting removal.
3 screws. Two behind the little "trap doors" above and below the door pull. Pry out the caps for these. Third is behind the door handle. Put a screwdriver behind the plastic panel (towards the rear of the truck) and pop it off to get to the last screw. That's it!
