2012 drive line issues
2012 drive line
There is a TSB for testing & replacing the drive shaft, as I recall.
I had a minor clunk/jerk at stop/start sometimes. Dealer tested then installed the updated part under warranty, the TSB called it propeller shaft if I recall.
Might be you're getting worse symptom of this problem. Hope this helps.
Dave
YOU LIVE IN THE COLD NORTH NOW ? best not grease it until , it warms up.
I grease the drive shafts/yoke every oil change ...
only 2 pumps no more ..moly on the splines and lithium on the U joints.
youngrk
