2012 Trail skids
aaatkr
Can anyone tell me what skid plates came standard on a 2012 Trail edition? Steel, composite, etc... and how much coverage they provided? Thanks.
Steel sheet metal skids that all the models had up to 2024 . Pro with its front aluminum skid being the exception.
As NickB replied, they are sheet-steel from the factory.
They cover:
  • splashing, between the radiator and the engine. And I guess the steering, oil-filter, transmission-cooler-lines and stuff that passes through this frontal area
  • the engine oil-pan itself
  • gas tank
The OEM plates do not cover the transmission, transfer-case, etc.
They cover:
  • gas tank
Not a 2012 but on my 2011 this is what I have and its all factory.
I would venture to say the stock skid-plates are "satisfactory".
By this I mean when you're off-road, you are best to consider the OEM skids as "Early Warning Devices", and either back off or choose a new line to overcome an obstacle. When you feel that sudden jolt, or hear the initial screech on a rock, reconsider.
If you need a BIT more protection, consider welding angle-iron (I've used old bed-frame angle that I could find for free) as stiffening-ribs. Do this on the top-side, add some fresh paint, and it will look pretty good. With this improvement, you could probably get away with screech-dragging over modest obstacles. Beware: the transmission and transfer case remain exposed! I recommend covering these with aftermarket skidplates, or having a great pair of boots for when you have to hike home :lol:
However, if you're intent on dropping off rock ledges and landing on your skids, or bouncing and hopping your way up a a rock-waterfall, you'll want to look at something aftermarket, 1/4" thick or so. And probably carry spare axle-shafts. And a winch. But if you needed this much, I don't think you'd be posting here.
erinobr2000
