2013 4runner gas mileage getting much worse?
Since you noticed a "change", I would suspect a maintenance item might be to blame.
Simple things like air filters and plugs. Dirty fuel injectors. Dirty MAF and/or throttle body (both easy to clean). Bad o2 & F/A sensors. Tire inflation pressures, etc.
More complicated things like wheel bearings, brake drag, etc.
I get 19.3 everywhere. It dipped a little when my throttle body was dirty and when I ran lower tire pressure.
FPNI, start with basic maintenance and a little love.
Change oil, air filter, clean MAF, throw a bottle of BG/Techron/etc in the tank, and most of all—sparkplugs. And spring for the double iridium ones while you’re at it.
That’s all I got
Gas mileage Is definitely more efficient at altitudes, that's probably 90% of your "problem," if not all of it.
Sent from my SM-G960U using Tapatalk
OP, you did not clarify where at sea level you are at.
But I am with Electro Boy on this. Being from SoCal our fuel blends change from winter to summer. (AQMD rules) this effects MPG.
I also agree with adding or buy fuel that contains Techron to keep your injectors clean. I have done this for years and believe that it works.
I am not familiar with Colorado fuel but do they have season blends for there gas? I have been to Denver and if they don't they should.
Ethanol added to gas helps with emission but it hurts MPG.
leolediola
