They are a lot longer but they don't fit our upper shock towers due to the bolt pattern, and the lower bushing size might be different too.
I have some 02 tacoma trd springs and shocks in right now, I was just wondering if there is any difference in the newer (new) 13 tacoma. A guy lifted his truck and gave us his old shocks/springs and leaf springs.
Any height difference in old/new?
Im going to buy mine this weekend. The ones I found are yellow-yellow and yellow-white from a TRD Taco 2013. Still looking for good deal on some Tundra 5100s.
Best deal I found on Tundra 5100's was on jet.com
Just going to bump this thread again, anyone have any updates?
Does anyone know if 2nd gen Tacoma TRD springs are all the same or did they change over the years?
I am thinking of giving this a try.
I am going to buy a set of 2011 TRD springs tomorrow morning unless someone tells me not to
Have you bought yours and tried them yet? I just got mine today. Waiting on the 5100s to come in.
I ended up getting up Tundra TRD access cab springs, from the research I have done the Tacoma TRD springs will work and might even be better then the tundras they are slightly higher then stock spring rate and are not as large of a diameter as the Tundra springs, which is good the the Tundras are a pain in the ass to install (on the third perch) mainly due to their large diameter.
I hope the Taco springs work out for you! From what I understand they should give a very similar lift in terms of height to the tundras
Well, guess I'm a guinea pig on this. Do you know what perch I should run them on? I want 2-2.5" in the front.
My guestimate would be the 2nd perch your going to be running them on Tundra 5100's right? 3rd perch would be closer to or over 3"
I'm in the beginning of a 97 build. Tacoma 05 springs with tundra 5100's should get 2-3" up front depending on the setting correct? Part number 24-188265 for the strut?
