2014 Driver’s Seat Popping, Creaking, Squeaking
I am having the same damn problem it started 2 weeks ago 4runner has 27697 miles on it. :mad2:
T-SB-0051-12 - Driver’s Seat Popping/Creaking/Squeaking From Lumbar Area (March 1, 2012)
Some 2010 – 2011 4Runner vehicles may exhibit a condition where the driver’s side seat back lumbar area makes a pop, squeak, or creak noise while driving. The condition may become more evident when driving on rough or uneven road surfaces or while moving around in the seat, especially if the lumbar support is fully extended. Replace the front seat back spring assembly to address this condition.
Tip!
Guys here is a tip: what I did was extend my seat (lumbar) all the way to the back, where I would usually have it, since I am 6 foot. I then moved it half an inch forward, and now it is gone. No more popping, squeaking, or creaking from the lumbar area anymore, even though I wish I had it all the way extended, but that is not a bother to me. Now I am a happy camper! :dance:
2015 having same seat popping
My 2015 SR5P started having this issue, does anyone with a recent model other than Speedy have this problem too?
It's a popping in the driver seat lumbar area when you move around the seat (bumps, turns, heavy acceleration)- pretty annoying. It's somewhat intermittent, but I'd say present 70% of the time when driving. I've got my 20k service coming up so I'll have the dealership look at it if it continues, I'm sure it won't be happening when they take a peek. Just curious if others with a 2014+ have experienced this.
My 2015 TE has been doing this from the drivers seat when vehicle in motion. I can recreate it by taking a slow wide turn. I will do it with the AC and audio off. Back seat does it too when I have passengers. Gonna have stealership look at it on my next service. Its annoying for sure
I just went and had my 20k service at the dealer and mentioned it to the tech. They looked and said it's due to the lumbar support air bladder slightly shifting when it's partially filled. According to them there's nothing they can do about it, replacing it likely would create the same problem with the new bladder so it's not warranteed. That kind of makes sense, but it's annoying when it does happen....glad I'm not the only one. Let me know if you get a different answer 5onthefloor
About to get my 30k maintenance done. I'll update when I hear what they got to say. I'm gonna try to see if deflating lumbar support helps. That does not explain the backseat tho...
Just had 30k service done. Turns out the hinges in the back seat were the cause of the noise I was hearing. Dealer adjusted and lubricated the hinges.
Wow, wish I read this a loong time ago. Was getting worse and worse. Had a buddy drive it to hear it, thinking possible a lose seat bracket, he came back and didn't hear it. He's shorter than my 6'2" height and needed to move the seat forward.
So I pushed the bottom slider button forward for a split second and the sound seems to be gone now.
Only drove it 4 miles since then so it'll get tested out this weekend.
I have been having this exact issue with my 2016 4runner with 7500 km's on it. It started doing this a couple months ago, I took it in to one of my local Toyota dealerships (Country Hills Toyota in Calgary AB) and they said it was "normal" and they all do this. I then brought the issue up with Toyota Canada and they arranged for me to take it into another dealer. I took it into Charlesglen Toyota this past Tuesday and the service manager ordered a new complete seat frame that they are going to install to try and get rid of the issue. I am a little worried now after reading this thread that this will not solve the problem since you guys are experiencing the same issue as well.
My 2015 sr5p has the drivers seat pop, I thought it was me being a fat ass but with only 9,000 miles I think something else is going on. Mine started around 3-4,000 miles.
So I ended up having my seat frame replaced by Toyota. So far the problem has been resolved, but we will see if it comes back after some Km's like it did when the truck was new.
I'm glad I found this thread! So I'm not crazy.......my seat does this too, seems to do it in all positions and with/without lumbar inflated.
Has anyone found a permanent fix for this?
My 2016 TRDP goes in for its 25K oil change tomorrow...and to have the crazy creaking, popping seat looked at.
No back/forward/lumbar adjustments make any difference.
I'll report what my dealer finds.
-H-
My creaking/popping was apparently coming from the seat rails. Dealer is replacing the rails under warranty.
-H-
Has anyone found the culprit for this? My TRD OR just started doing it and it drives me crazy! It only has 900 miles on it!
Has anyone found the culprit for this? My TRD OR just started doing it and it drives me crazy! It only has 900 miles on it! ��
mine started around 1000 miles as well; took it in and the dealership said it was the rails and due to having the seat all the way back (I'm 6'4"). I moved the seat forward and the noise stopped.
I've had the same thing at least when it comes to the popping ha. Always wondered what it was but figured it had to do with my weight (over 200 lbs). Never thought of adjusting my seat.
lubed the seat rails with silicone brake grease seats move better, less pop when adjusting .. when it the position I like no movement of noises.
I had this problem on my gm truck . there was a rubber stop that broke down so I fabricated a rubber to set in that spot no more seat popping .. had to do both seats. GM truck was 10 yrs old when this started got worse so I had to break it all down took a few hours ..
