2014 Questions / Issues
kmc0929
2014 SR5 4X4
3 small issues I'm running into...
-They did not include auto headlights on this trim package, how feasible would it be to have the dealer install this option? I wonder if the dashboard is already "plumbed" or wired for the sensor etc.
-For some reason there is no option to change the key fob (not smart key) to have it open all 4 doors with one click. It was an easy option change on my Camry. The dealer couldn't do it.
-Last problem, this vehicle has about 5,000 miles on it now, at its developing a "thunk" somewhere near the driver's side front end. It happens when coming to a stop and starting back up, IE) a right turn on red type of thing.
Any ideas?
Any ideas?
Have you tried holding the lock and unlock buttons simultaneously for about 5-7 seconds? The car should beep multiple times for "unlock all doors" only once for "drivers door only"
This worked on my 2010 Limited not sure if this applies across the board....
I have read on this forum somewhere over the years, the driveline thunk noise is completely normal. Mine does the same on acceleration to go, usually just after a more harder stop at a stop light. No worries with that. I have 113k on mine now never any issues. Just routine tires and brake pads wear.
I leave my head lights on all the time for DRL. They auto shut off after a few min once the car is off and they come back on automatically on start. Only issue is the interior dash lighting will be dimmed, sometimes hard to read the older orange back lite radio. Entune may not be an issue. Two clicks on the fob lock will turn the lights off instantly as well.
KS
