2014 SR5 w/ lift, can I fit 295/70R18 cooper s/t maxx?
Scummy13
What's up guys, I got a '14 4Runner with the lift they put on from the dealer ship (I believe is 3"). can I stuff those cooper st maxx 295/70R18's under this thing without any trouble? Alittle rub is ok, I got 35x12.50R20 cooper stt on my 2011 tundra rock warrior And I get some some rubbing in a tight turn But nothing major. What do you guys think?
You'll have to do the body mount chop and extensive trimming. I'm running 305 70 17 which is very close to the same dimensions but I also have done a little modding beyond the lift.
They will fit thats the size im running on duratracs! You will rub bad if you dont do body mount chop and move or remove the front liners.
how far do I gotta go down to avoid the body mount chop. Those st maxx were a 34.25"x12". Do you think I could drop abit in height to a 33x12.5, which by cooper tires spec sheet is a 32.68" tall?
275/70/17 is going to be the largest tire you can fit through full suspension travel without cutting (assuming stock size/offset wheels).
Normal lifts on IFS Toyotas do nothing for you as far as fitting larger tires, they just change the static sag ride height.
I'm running that same tire on my 2014 and it still rubs after body mount chop and aftermarket control arms with as much caster as i could muster.
