2015 Limited front suspension creak
Drew1122
Junior Member
Hi Folks, I have a 2015 Limited 4wd, completely stock with only 28,000 miles.
There is a creaking noise in the front suspension when going over small bumps etc, also when turning the steering wheel back and forth at slow speeds. Sounds like it's coming from the front left but not 100% sure. Sounds like a dry bushing somewhere.
Have lubed the hood latch, rubber piece under the wheel well that makes noise on some Runners, the drive shaft, and also took apart the sway bar bushings and cleaned and lubed those with silicone grease.
Anyone know of anything else to check? Thanks...
Check the fender liners behind the wheel; it is held together by a clip. The noise on my Limited was caused by the liner being loose. I used a small zip tie where the clip was and that solved my squeak.
Seems like there is a thread on this posted almost every day...
I had the same issue, for what it’s worth, and mine showed up around 26k miles. Just traded in for a 2019.
charlesz
