2015 Toyota 4Runner Lighting Guide
Hi everyone,
We have been getting a lot of questions regarding lights for the 2015 Toyota 4Runner. We do have a vehicle lighting guide, check out XenonDepot.com for the 2015 Toyota 4Runner Lamp Replacement Guide to help if you are unsure of what bulb the vehicle uses for the low beams, high beam, interior lights, etc. We have all model years available. Hope this helps.
John
How long would you expect the Phillips 4300K bulb to last. Had mine about 4 years, just curious. Its the 30watt kit on a 2014. I swapped it from my 08 that had projectors as well.
Sweet! The bulbs are rated for approximately 2000-2500 hours.. so it's really a question of how often you drive your vehicle.
Steve
Are you sure the 194 is OK for the license plate bulbs ? I ended up cutting a bit off the end of the 194 to fit better...It was hitting the housing otherwise.
TerryNap61
