2015 with drivers lean HELP
TRicks4
I have a 2015 4runner sr5 with the ready lift3/2 set up. My drivers side is just about a half inch too low. Toytec has a spacer that will fix this problem. My concern is that I don't know if the ready lift spacer and this toytec spacer will not work together.. Can someone shed light on this??? I called toytec and ready lift and they were unsure and couldn't promise anything
link is the spacer that will fix the lean.
Front Top Plate Spacer (One - 1/4")
thx in advance
It is really going to depend on how much thread you have. Looking at the ready lift kit, you should be able to place the 1/4 spacer on the top or the bottom of strut extension if you have enough thread for it on either side.
AndiGarage
