2020 4Runner - 2WD vs full-time 4WD?
kaitlyn2004
I am looking to get a new adventure vehicle, and it seems likely that it will be the 4runner. Will be test driving one next week!
We have some slight differences in trims in Canada, but it seems only the Limited+Nightshade have full-time 4WD.
I currently have an Audi Q5 with (what I believe to be) very well-regarded AWD system. I live in Vancouver, BC so I experience varying conditions. I've never driven a "truck" before, nor dealt with these 4x4 systems.
I might be driving around the city on wet pavement, or up (paved) mountain roads in pouring rain? Might be driving up to a ski resort where it's mostly plowed but icy patches or slushy conditions. Going offroad on gravel, etc. Driving offroad or even mountain passes in winter season with varying levels of snow on the road.
From my limited experience, 4Hi is something you switch into when you need it, and not to be driven on bare/dry pavement. It also has a max speed, I think? I think I read somewhere it shouldn't be used for prolonged periods/over long distance?
Isn't RWD bad compared to FWD in poor conditions especially winter?
This seems like a slight recipe for disaster... but obviously these are already being used in this city and whatnot, so what am I overlooking or misunderstanding?
You definitely don't want 2WD. You're correct, RWD is not ideal for winter conditions (even with traction control).
4WD is something you engage on-demand. When it's not engaged, you have less wear and tear on your transfer case and also have better fuel economy. The downside is that you have to be aware of what your driving conditions/terrain are and actively engage it when appropriate.
AWD is always on, so worry-free in all driving conditions/terrain. You do sacrifice fuel economy.
So with the non-Limited trim I don't have the option of the full-time 4WD (toyota.ca is calling it Full-time 4WD and not AWD?).
So basically when I am driving in, approaching or leaving these sorts of conditions I'll have to make habit to switch in and out of 4HI and that's just how it is? I'm sort of envisioning this whole thing as a non-issue since I see 4runners all over the place... it just seems weird and potentially most dangerous than your standard FWD car even...
Not dangerous, just different. If you pay attention to road conditions you'll know when to switch in and out of 4wd. Might be a little bit of a learning curve coming from AWD, but over time it will be natural and almost without thought. Keep in mind that for on road travel you will be in 2wd 90% of the time anyway.
If it truly of great concern, simply get a Limited.
Correct. Non-Limited does not have the option for full-time AWD.
It may sound dangerous, but it isn't at all. It's just not a common practice you're used to but doing it now, and then you'll be accustomed to it. You can switch on the fly as you drive but under 55MPH or in your case fellow Canadian, under 90 Km/h.
You can read more here
When you have a 4wd disengaged, you get a better feel for the road and can engage it when traction becomes an issue. awd lulls you into a false sense of security.
Unlike the TRD, it doesn't come with terrain select or crawl control. Now, neither does my current car and I've never used them in my life - but I imagine it's something I would be using more. Just yesterday was going down an FSR with my friend in her wrangler and noticed her using crawl control.
Likewise... my previous-previous car was a honda accord, which I assume is FWD? Also a sedan and an incredibly different car overall. So I'm just so used to the AWD on my Audi Q5 to the point I don't really know what it's like driving on slippery roads or other non-dry pavement conditions at city or highway speeds when you're RWD.
sounds like you might like the lexas gx460 better
Reading through that link now, thanks for the info! The whole 4x4 aspect is definitely new to me.
A specific question to help give me some context - I remember driving the very long gravel (at least 50km long) Spray Lakes Road near the Canadian rockies - I believe it's a maintained gravel road, but also has varying degrees of potholes and ruts over the season. I didn't love driving it in my Audi Q5.
A few examples of the road:
https://live.staticflickr.com/65535/47083405114_7c706d8c4a_h.jpg
https://out-of-canada.olehelmhausen...ueber-canmore-ins-spray-valley-8-1024x768.jpg
https://live.staticflickr.com/6131/6017862745_945d691e4c_b.jpg
https://previews.123rf.com/images/g...rail-in-kananaskis-western-alberta-canada.jpg
I would assume if I was "very cautiously" driving, I would just leave it in 2HI, but what if I wanted to drive it like a paved road - would that be the exact case of 4HI? The link you pointed said avoid dry pavement due to wheel spin and turns, but I assume this gravel introduces extra wheel spin and traction loss that compensates any issues? What I've I'm ALSO on one of the terrain modes that maximizes traction on this type of surface?
(somewhat side note, potholes are notorious for damaging car suspensions and whatnot - is the 4runner being a body on frame and having more proper suspension able to cruise over the uneven terrain without the same kind of worries? I do often see trucks blowing down these types of roads and not sure if it's capability or stupidity!)
Thanks so much!
It's come up a few times... quite a bit more expensive and even worse fuel economy :(
Debating in my own mind, but also trying to find that "comfortable" capable vehicle, that isn't so expensive that I'm also back to square one of risking damage to it and repair costs and whatnot. I've avoided some roads in my Q5 just to avoid tree branch scrapes :)
With RWD, you just have to be smoother with acceleration in slippery conditions, especially when turning. I roll off the gas when approaching overpasses to be safe (due to changes in materials such as concrete and blacktop). The thing to do is to drive it in an empty parking lot when it's wet or there's snow on the ground to understand the sensation with and without 4WD engaged.
Just wanted to chime in and thank you guys for your help and insights so far! This "truck world" can be intimidating for a female and so many typical "truck guys" chime in mansplaining or recommending things totally unnecessary as I'm not a hardcore offroader, so thanks!
I got the Limited, rather than Trail w/ KDSS; that's what I was torn between. Both have good on road handling manners (i.e. less truck like), but among MANY other things, the biggest difference was the drivetrain.
This vehicle was bought for my wife, and she was not comfortable with RWD and engaging and disengaging 4WD at the proper times. It was an easy choice.
If you haven't driven any, try a Limited and another trim. Hit some on ramps/cloverleafs. I guarantee the Limited will be the easiest transition from your former vehicle. The wheels kind of suck for potholes though, it comes with big stupid 20" wheels...
Yes, I was going to chime in and mention the 17” wheels being key for pot holes. Low profile type 20” (and for that matter 18”) are not off-road worthy and not suitable for long gravel roads with potholes.
If you want to be more like a Wrangler, don’t get the limited. But if you want a full time 4WD that you don’t need to think about then get the Limited. I would say that rain on pavement is not really suitable for part time 4WD center differential.
Good luck and hope you make the switch. Great trucks.
I agree. If traction is an issue, turn the knob.
AWD is fine; if you like the limited, get it, enjoy the AWD. It also comes with 4WD, so you will have both.
If you really like AWD, and can swing the $$$, get the limited.
If AWD is not important, then don't worry about not having it.
If I lived on the PNW, I would appreciate AWD, but not enough to move my cheap derrière into the limited trim model. I have the SR5 and am satisfied with it.
Even taking cost out of the equation, I'm not sure which I would get haha.
- Limited gets full-time AWD - obviously "better", not sure on impact to fuel economy on an already not-efficient car
- Limited gets X-REAS instead of KDSS. I wouldn't know diff between on-road and off-road handling.
- Limited gets front+rear clearance sonars... I assume these are just the parking sensors? I really love these, would probably just add them aftermarket if needed?
- Limited gets bigger wheels - that's unfortunate... would need to replace tires AND wheels... just added cost
- Better speaker system is nice!
- Leather vs softex - maybe softex would actually be better? Given the utility aspect
- TRD gets locking rear diff. This almost seems described as "get out of jail" to really increase chances of getting out of a jam?
- TRD gets crawl control+terrain select... on paper, this seems like the biggest difference and something that SEEMS like I should definitely have
Limited Body Style vs Other
I am older female and no doubt about it, hands down, I belong in a Limited. Easier to get in and out of with the automatic and lower profile step boards. Only the Limited offers AWD (all 4 wheels always engaged on all roads) and this was the right choice for me as I don't do any off-roading but need a capable vehicle in challenging road conditions.
So why did I get an SR5 Premium? Because I liked the looks of the SR5's teardrop front round lights and absence of the Limited's chrome trim which creates a lower body profile and less sporty look. As Billy Crystal would say (channeling Fernado Lamas) "It is better to look good than to feel good".
I also considered going all out for the TRD Pro with the TOYOTA letters on the front grill but it looked a bit too Rambo (if I were a few years younger maybe) so SR5 premium with Soft-Tec leather seats and Moonroof was a good choice.
Take a look at Limited Vs. SR5 Premium vs. TRD Off Road vs TRD Pro and see what you think. Limited's are so very popular and many people prefer the look of the Limited over the other more sporty body style.
Based on you’re criteria and driving habits, I agree that the Limited is your best option.
You do have to do something when it comes to engaging 4HI in the ORP/SR5....pull lever or twist knob. My 89-yr old mom told me “engage it, that’s what you bought 4Wd. And she is right! Just don’t run it on dry pavement!
You mentioned about crawl control. That’s a specific topic in itself and I do not know how it works on other brands....in the 4Runner, read this link since it has some good info. Top speed is 5 km on crawl control
What is Multi-terrain select? - Toyota 4Runner Forum - Largest 4Runner Forum
Good luck!
Bob
The only thing you mentioned that I don't believe was added to a limited already was kdss. I believe the GX 460 does have kdss and x-rays on certain terms. That said, you can add locking axel differentials, front and rear, aftermarket to any 5th gen 4Runner.
As far as styling goes, if you're not good with the looks of The Limited, you can swap out the front bumper. Plenty of write ups on it.
And if you're concerned with brush damage to paint, like I was living in the Rust Belt, Northeast United States, looking to goat armor.
Truck body armor - Go Off-road Armor Tech
One of the better Investments I've made. I've raked up against branches without issue.
As another Canuck living in Ontario, we get rain, snow and plenty of freezing rain. I went with the SR5 (premium is standard in Canada). The Bridgestone tires have to go though. I found even in 4Hi they still suck. The softex is nice and easy to clean. It's pretty easy to switch from 2wd to 4hi in an SR5. I had a Land Rover LR3 with terrain response, very rarely used it. And as for flying down back roads, I've always maintained, As slow as possible, as fast as necessary. That advice always seemed to get me home in one piece.
mek
