2020 fuse box diagrams?
trailer brake control
Have a 2020 trd off road and the spot to plug in the brake controler is dead no power at all so wondering about a fuse.
Since where looking at this fuse box has anyone added the raptor running lights from running from tacos. They add there fuse in the fuse box but since the 2020 is different anyone know what fuse to use?
Use the INJ fuse location if you want them on when the vehicle is on. Far left if your looking over the side of the vehicle. Although once plugged in there the lid might not shit fully. That lower left clip will be left unhinged.
If you just want them on when the headlights are on use one of the low beam locations.
Yeah, If you watch there video install you loosen that car bolt and run the wire up under the fuse box. Runninfortaco video. Thanks.
I have a similar issue. I have a 2020 trd off road too and I have bought a brake controller and wired it to the pig tail in the glove box. But when I plug it in the dash lights up with all the warnings from the safety sense. When I unplug it the lights go away after a few seconds. Everything I have read it’s just plug and play but I can not find anything specific to the 20s with tss. I hate to take it to the dealer for a possible blown fuse or something minor.
Yes getting frustrated This all worked fine in my 2014 but now same set up and nothing.I emailed Tekonsha makes the controller and was back and forth with support but no help there either.So it is likely off to the dealer.
I removed my DCM fuse for max privacy reasons. It broke my remote start using the keyfob. Replaced fuse, works fine.
Yeah, mine broke the hands free microphone so no phone calls and no Siri. Not cool, I also put it back for now and will find another way to kill the unwanted data sucking.
I did that and you're exactly right the fuse lid will not close. Will it be harmful to leave it cracked open like that? Wonder if there is a way to use the DRL fuse if it exists, I can't seem to find any diagram showing it.
I'd like the raptor lights to come on with the DRL's just don't know how without using the INJ fuse location and having the fuses exposed because the lid won't close.
Sent from my SM-N975U using Tapatalk
I'm in the same boat, would it be ok to tap into the IGN in the cabin as an alternative to INJ? For my Morimoto XB DRLs
Oooo thanks for the info! Was looking where to attach it too.
AlaskaRuss
