2020 Limited - Air Inlet under vehicle
kind of weird to have an air cooler under the body...
It has a bit of an lip on the bottom so maybe it blocks some of the air flow. The air duct draws from the lower grill. Must be the high performance petrol convective lubricant cooling system.
It's not brake ducts, it's pretty much dead center and draws air form the lower valence that only the limited has.
The blue is the air inlet and the plastic duct is outlined in orange.
I suspect that what ever is behind this want's some air, could be the front diff?
I found http://www.toyota-4runner.org/4th-gen-t4rs/207277-oem-skid-plate-differences.html, which references Gen 3 but still could be valid.
Very interesting. I just ordered an RCI plate. Now wondering if I should send back? Don't want to mess up air flow or something.
I did see an air channel going towards the Oem skid. But I removed it and added the TRD skid plate. Hope I didn’t mess anything up :-)
OK I actually found the right part now. It's called "Intake Duct - Toyota (52812-35010)". It in the Radiator Support section, not sure why, but I'm sure it involves an archaic process and 14 engineers. The previous picture is actually brake ducts. Sorry for the confusion.
As for a skid plate upgrade, I can look at the Toyota approved TRD skidplate. According to Toyota Parts the TRD Skid Plate, fits the 2018 Limited 4wd and the 2019/2020 4runner. The 2018 has the "Wild Flower Intake" as well.
If you look at the TRD Skid Plate it doesn't have the "Wild Flower Intake", but it does have vents in the middle. So I suspect the RCI should be OK as long as it has the vents. With that said, I'm not a thermodynamics engineer for Toyota, so use at your own risk.
Please post back when you get it installed!
Yes I have the Oem TRD skid plate [emoji40]. I have not seen any issues with my limited.
I have an 18 LE with and RCI plate. No issues to date, simple install...yes, that ducting all came off and I didn't think much of it.
Totally fine...
I took mine off 5 years ago and also trimmed a lot of that low hanging plastic on the front. The skid plate on the limited is the same as an sr5 and has a hole with a screen on it where the air goes in. If you do not take it off it will be easily torn off the first time you go off road.
