2020 TRD Pro 1" Front Lift
[MENTION=318203]Ryan at Eibach[/MENTION] I would so give you my truck for this... little too far away being in SC.
What measurements do you need? You can DM me if you want to talk or FT.
Can you give us an update on upcoming coil lifts for these 19-20s?
I cant give any updates until I can actually get my hands on a truck.
If any of you jokers are on socal shoot me a line. I need to get a couple measurements and cant seem to find a damn rig :(
Ditto. I'm picking mine up tomorrow. If you need a second set of measurements I can get you some.
Sent from my SM-N960U using Tapatalk
I measured mine and the rear is 1.5" higher than the front. Not sure if that's actually different from the 2018 and earlier Pros.
Well, I drove it awhile and put my heavy supplies tote in the back and it looks like the rear is 1.25 higher than the front with that extra weight. So I ordered a Cornfed 1" front only. Should be similar to what I had and liked in my 16. Will post pics when it's done. Will probably be awhile.
I think you'll be happy with it. I went 1.5/1 so I could throw 285s on and because the small lift is enough for it to not look "stock".
If nothing else, it'll hold you over until the Eibach kit is out.
I agree with [MENTION=175782]jcalvert86[/MENTION]... unless you want a really visible reverse rake go 1" btwn front and rear.
Did you see Tejas' post# 93 from "My TRD Pro Lift" thread? The 1.5/1 looks pretty darn level with maybe a hint of rake. Perfect. That whole thread is pretty helpful, expect there's only 1 '19 on there. I hope to have mine completed in the next few weeks and will post pics.
That's what I'm going for. I'm going to run through the stock 265s then go to 275s after that.
The only issue with this is that when load up, you will definitely squat.
I've been reading through these threads. I have a 2020 TRD Off Road with the TRD Pro Fox Suspension. I want to lift the front without jeopardizing the fox suspension (no top shims for me). Anyway, I was looking at new coils to do this, either the Eibach TRD Pro coils (front only) or the Dobinsons (C59-748) front coils for the TRD Pro. DOES ANYONE have any input on these? Eibach offers 1.6" of lift and Dobinsons offers 1".
I'd like to know which would be the best option? This is mostly for looks and I intend to keep my 265/70/r17 Falken Wildpeaks on. I'm not a big fan of countering the R&D that goes into these vehicles.
thanks!
