2021 TRD Pro Fox suspension as an aftermarket option
I think it would be more accurate to say that 2.5" shocks are required, not the fox shocks, at least for the 19/20 version of the shock. Otherwise, other coils wouldn't be compatible with the shocks, ie Icon 158504's or Kings. The lower spring perch on the '21 has changed, which seems to limit aftermarket offerings further to only the Westcott "not-a-spacer" or the Eibach redesign forthcoming.
Correct, thanks for clarification. I believe Eibach has mentioned newer spring design for the ‘21 later this year.
Since the lower spring perch changed on the 21' model, would the TRD Pro Fox kit part # PTR61- 89210 work on my 2019 TRD Off Road ?
Never mind !
I just found out that the spring perch is on the coilover & they will fit my OR.
Hey guys, I am considering the 2021 TRD Fox suspension that comes stock on 2021 TRD Pros for my 2019 ORP. I like reputation, fitment, and looks. 2 questions. First, what size lift will I get in the front and rear? I want to fit 285/70/17 tires on 0 offset wheels? I have spidertrax currently and dont mind some body work. Second, what other parts do I need (i.e. diff drop kit, rear springs, etc.)?
I’m considering this as well. I just got a 2021 ORP and I plan to run 265 ko2s I just would about an inch of lift in the front with a little Better handling and less nose dive on braking. I was debating between bilstein 6112s or getting a used pair of fox TRD pros front take offs.
I put fox trd shocks on my 21 trail. Night and day difference. Well worth it
erinobr2000
