2021 TRDOR high beam replacement to LED?
Yup, works awesome. Half bright with DRL on and no flicker. It came from retro solutions but they aren’t around anymore. Been running it since 2018 with 0 issues
Any name or make? I am really looking for working plug and play LED's for the 2021 headlights, which are new this year, it has LED low beams stock, and Halogen high beams. Thanks for the reply.
one of the best quality led bulbs on the market and very reasonable priced. Very very bright! I ran them in my low beams and fogs since 2018 before I swapped in 2021 headlights.
Here is a link:
GP-H11-CR-HL-IV
Another '21 owner here. Basically any 9005 led will work. Just depends on quality you want. The few ive tried have all been dim while on the DRL setting and bright AF on high beam. The problem is that the DRL brightness is still really bright during the day and still looks like your high beams are on. Theres also a slight flicker with most leds under $100.
If you check out the next few pages here theres a couple other threads discussing the same topic over the past couple weeks
SV.4's from Headlight Revolution work for me
I've shared this in other threads, but just in case you haven't run across those posts:
I have a 2020 TRD Pro and replaced my stock lights with LED's from Headlight Revolution right after I bought it last April.
If you google Headlight Revolution, you'll find them. These are the SV.4's.
As far as I'm concerned, they are worth every penny so far.
Only problem with these is that the 21's are LED from factory and they're actually built into the unit. Stock output is pretty amazing in my opinion... But your headlights look killer too.
Are the high beams LED on the 21's? I was thinking it was only the low beams or maybe I have that backwards?
Only the TRD Pro and Limited trims have LED high beams. The other trim levels only have LEDs for the low beams.
Regardless of whether or not they have LED high beams, all trim levels still use an incandescent halogen bulb in the traditional high beam location as a DRL bulb.
What he said. My 21' ORP came with halogens in the high/ DRL. Pro and Limited low/high share the same projector.
AUXITO has a complete 2014+ Toyota 4runner LED bulb upgrade kit, all bulbs are plug and play without any modifications.
If you think the LED bulbs in the kit are not bright enough, you can choose our brightest headlight bulbs from the Y13 series.
Deka
