22RE no longer starting
Only took a week but finally got around to testing the fuel pressure and it's looking like a new pump might be in my future. Here's what I got at the cold start injector and the inlet to the fuel filter.
So unless there's something else I need to check first I'm getting a new fuel pump....
yeah, that's definitely not enough pressure. the good news is these pumps are easy to change with the access panel under the rear seat.
pump is likely done. i know, i went through 7 or 8 pumps about three years ago. best mod i made was to install a pressure gauge at the CSI.
Got it running again!
Put a new fuel pump in it and the psi went right to 44 (top of spec per the FSM). Still didn't want to start until I got the body grounded to the block. Used a jumper cable to do it and as soon as I took it off it stalled out immediately, so I just need to fix that permanently.
Thanks again for the help everyone!
Good catch on the fuel pressure!
Like Wallytoo, I also installed fuel pressure gage... mostly same parts, I think.
My Write-up here.
I'd really like to replace it with electrical sender and display in dash, but that's low in list of priorities.
