2500 arb awning on stock roof rack
boyguan
I’ve seen a few people go with the shorter on on the stock rack but I want the longest one.
I believe the arb has a aluminum backbone already so it should not flex
Anyone try it before?
Are you sure you want to mount a 2500mm? Thats seriously long. The vast majority of us use the 2000mm and it will cover everything aft of the front fenders. The factory roof bars aren't as long as many aftermarket racks, so your mounting points will be closer together which may cause instability with an awning that long.
The 2500 extends past ARB's recommended mount spacing when using the factory roof rack. That said, I've run it on the factory rack and for a temporary setup it seems fine. I wouldn't plan on it as a permanent solution.
I’m sure I want a 2500. Now do I want it on a stock rack. Not sure.
Might just get a 2000 until I decide what I want to do about a rack
Ultimately your decision, but I would strongly advise against a 2500 on the stock rack. How about factoring in the awning length into your rack criteria to ensure it will safely and securely mount to it?
Here is a link to the 2500mm owners manual: (http://www.xtreme4x4.gr/pdf/ARBAwninginstructions_lowres.pdf) and inside you will find under section 1, step 3, the maximum overhang distance from the outside brackets (700mm per side, or 1400mm overall).
Hope it all works out.
On a stock roof crossbars.
youngrk
