265/65R17 vs 255/75R17 vs 265/70R17
HiVel-JR said:
I am going to say no. The rubbing would be an issue. (you could shave away some of the plastic) When I had the tires put on originally it was a very close fit, the guy at the tire store said these are not going to fit. I told him just put them on and I
would judge the fit. They did fit, but only by less than 1/2 inch on the front side of the wheel well. But they only rub in reverse when I cut the wheels, but it is avoidable.
hope that helps.
If I understand this correctly, with a 1" leveling kit, that should solve the problem...Right?
For what it's worth for the Discussion. I installed the 255/75/r17 JK Rubicon tires on my wife's 3rd gen months ago. I love them and will do it again. I got them with 400 mi on them.
As shown with a OME Lift.
Nick
IMG_8610.jpg~original
IMG_8867.jpg~original
Nice pics, I like them as well. I need to get one of those bumpers, but I have too many toys on my wish list....
darnit, too many toys!!!!!!
golfinw71 said:
Does anyone know if the tires would work without the 2/1 cornfed lift? And if so, how much rubbing would there be? I have a chance to buy a set at a really good price and was thinking about putting them on.
I'm trying to link back to an earlier post. This is a big tire that's working well on an 08 without a lift. Hope this works.
275/70r17 GYW SA Pictures!! Sorry for the delay.
Here's the 275/70r17 GYW SA pictures I promised. Sorry for the delay. I liked these tires over the BFG T/A's because they provide the off road ruggedness but without the very rough look.
I think they are taller than the spec 32.2" They increased ground clearance over the original 265/65r17's by slightly more than 1 inch.
So far, all is great. The 275/70r17 GYW SA tires are working just fine with no lift or other mods needed. However I did move the front plastic inter-fender piece a little more forward, very easy. 3 screws into plastic at the bottom.
Not noisy.
6.3% error in odometer, no big deal.
Not sure about MPG yet.
The very slight rubbing of the UCA, only at full turn, is of no concern and totally negligible.
Spaceman has attached this image:
__________________
2008 T4R SR5 V6 4WD
LT275/70r17 GY Wrangler SA
Min. clearance was 7.5", now 8.6", next 10"
Setup to tow behind MH
Waiting to add leveling kit.
Shame on Toyota!! Lied to me bigtime about gnd clearance.
Documents claim 9.1", they delivered 7.5".
Just wondering if you removed the "triangle" in front of the wheel too, or just moved the whole plastic piece forward?
Am I missing something or did the link not show up?
Triangle?????
I moved just the bottom end of the plastic piece forward about 0.75 inch. That works great leaving extra clearance for the bigger tire.
I was trying to link back to one of my earlier posts that shows all the detail discussion.
Couldn't do it. Can't figure out how to do that.
Can someone quickly explain how to do that???
That would be helpful.
fugarza said:
Do you have a link to the seller on ebay?
I was thinking about getting some of these as well.
Do they even know what a haole is? That is funny. You calling people haole....hehe
Reviving old thread As I believe this tire debate of 255/75/17 over 275/70/17 needs more life.. lol currently in the same boat myself and I’m leaning more towards the 255/75 right now although I’m fighting myself because I feel they will be too skinny.. but they are definitely the same in almost every other way the only major difference would be price of 255 should be cheap and also the 255 width is 10.0” as where the 275 is 10.8” so price and width are considering factors here which I am trying to get over...they are both TRUE 32” tire but do the skinny tire make a signicant difference ? How about handling? Or when the occasional off road situation?..
I have run the BFG 255/75/17's in the past with no complaints, currently running Cooper Discover AT3's. Much quieter than the BFG. I have a Daystar 3/2 puck lift, and 1.25 spacers. Some rubbing on the liners and mudflaps. Performance is great for what I do, I need to install the Bilstein 5100's to get a little more clearance.
What size are your coopers?
albertpeter156
