285/55/20 Trail Grapplers on Stock Wheels
Helix26404
Anyone have experience trying to cram 285/55/20 Trail Grapplers on stock 20" wheels?
I currently have BFG AT 285/55/20s on stock wheels with no lift, other than adjustable Bilstein 5100s on the maximum lift setting to level the truck. It looks and drives very nice.
When the tread was larger early on after I purchased the tires, there was a bit of rubbing on turning, but not too bad. Just wondering if the bigger lugs on the Trail Grapplers would be more of a problem.
I don't have the capability to measure anything as the Trail Grapplers in that size are special order (thus why I am asking this question because if I order them, they are mine whether they fit or not)...
According to the specs on both manufacturers (who knows how accurate they are) websites the overall diameter of the Trail Grappler is 0.1" larger than the BFGs. Can't compare the widths of the tires as the wheels you are running are too narrow for the spec range. If you rubbed with the BFGs you will rub with these. One thing we have seen here time and time again is two trucks with the same setup will have different outcomes. Only way to know how bad it will be is to mount them up.
