285/70/17's on 3rd Gen Limited 2WD
Havik
Hi Guys,
Sorry for the asking such simple questions, but I don't own a 3rd gen so I don't know much about them. My nephew has a 1998 Limited 2WD model that I would like to upgrade as a gift for Christmas. I have a set of basically new BFG KO2's in 285/75/17's in my garage that were on my 5th gen that I'd like to give to him.
What I need to know is what all needs to be done to run tires of this size on a 3rd gen Limited? Will a basic 3" lift be enough? He will be running stock 5th Gen wheels with these tires.
I was thinking of buying him these springs: 3" Lift Kit with front and rear OME coils
With these shocks:
Front Bilstein Height adjustable 5100 shocks
Rear Bilstein Shocks for 96-02 4RUN
Would this work? If so, will it be enough or would other mods also be required? Thanks in advance for your help. I know I could probably spend some time searching these forums but I figured you guys could get me all the info I need quickly, plus provide some much appreciated advice and first hand knowledge.
For lifting a stock 2WD with no extra weight that setup should be fine. I would extend the rear brake hose while you're at it. Not sure about that tire size on 17s tho... does he have 17" rims now? I'll let someone else jump in on that.
Very generous of you :bigok:
EDIT: given the other thread that just posted today about an LBJ failure, that might be the more prudent gift, but lifts and wheels and tires are more fun Lol
Good call on the brake lines, I will add that to the list. He currently has the stock 16" rims. Again, I have no idea if this will even work. I am hoping to get a lot of knowledge from you guys before I dig myself into a hole I can't get out of and end up spending way more than I intended.
EDIT: What is LBJ? I assume you are not talking about the President (even though he was pretty much a failure too from what I understand).
17" tires won't fit on 16" rims (wheels) so that's a no go
LBJ, Lower Ball Joint http://www.toyota-4runner.org/3rd-g...rview-my-daily-driver-ball-joint-failure.html
Right, the tires will be on stock, 5th gen wheels which are 17's. I just need to know if what I listed in the first post will be all he needs. Thanks again.
Your first post mentioned a set of basically new BFG KO2's in 285/75/17's in my garage that were on my 5th gen, didn't say wheels and, but that makes sense. Yes that should work.
Get a second opinion though, and also your title says 285/70/17 but your first post says 285/75/17 - that could make a difference to fit
I didn't make it totally clear, but in the last sentence of the second paragraph, I did say these tires would be on 5th gen wheels. Sorry for the confusion. Thanks for your help.
The only concern will be whether they rub the front upper control arm, which can be solved by spacers or aftermarket UCA.
Otherwise - short answer is yes, as the only difference b/w 2wd and 4wd are the rear UCA and drive shaft, from a "suspension" standpoint.
285/75/17 should rub very badly even with a lift. It will rub the UCA, the pinch weld near the fire wall, and the front bumper. Nearly a 34" tire. Anyone else agree?
They are 285/70/17, not 285/75/17. They are about 32.8" in diameter.
I think he'd be fine with that setup. But I'd definitely add some wheel spacers to the list, I don't think he'd clear the UCA without them.
I've got a 3 inch lift on my 2wd and I'm running 275/70r18's which are around a 33.2" tire. These are mounted on Tacoma Limited wheels. They would have never cleared the UCA without my 1.25 inch wheel spacers.
I'm also not rubbing the pinch weld at all, but I did have to do just a bit of trimming on my front fender flare :guitar3:
Oh okay. Still my 285/70/17 MT2's on 2015 trail wheels would not work without spacers. They would not clear the UCA. With the spacers I had to trim the front bumper valence but they clear the pinch weld.
All the same, sounds like you are a cool uncle to have!
Hi Guys,
With these shocks:
I wish I was lucky enough to have that done for me :) what a nice guy should turn out good
bobdjr41
