285/75/16
Looks nice!!
A little too snug for me. I rather lift my 4R more to accomodate a larger tire. Either way, looks good. All you need now is a 5 inch lift.
Hayn4R
05 Sport v6 4x4 Platinum
I did a trial fitting with 285.70.17s yesterday using some Wrangler ATR they had. I'm actually buying Hankook Dynapro M/Ts but they didn't have those around for the test fit. The 285 does rub the UCA at full lock. I already have 1.5" spacers on order and it looks like that will take care of that rub. I already took care of the liner on that side for the test and everything is a go. I also have a 2.5/1.5 Daystar lift so that does help.
Will post pictures when everything is installed.
BTW, I couldn't get the tire dealer to install the tires. They said that insurance regulations would not allow them to install tires more than 2 sizes over stock. So today I get to ferry all my tires back and forth so they can mount them on the rim so I can install them on the truck. :( :upset:
The tires are on and I love them. Don't have the spacers yet but no rubbing right now as long as I don't turn the wheel to the lock.
Lift spacers do not help the uca rub problem. Take a closer look!!!
When I said "1.5" spacers" I meant to say wheel spacers. I already have lift spacers installed. The wheel spacers will arrive on Monday I hope.
Nice addition to your ride.
What made you choose that brand of tire? That specific model? Did you see it in action or heard about them through the grapevine?
So you have a 2.5/1.5 lift plus 1.5 wheel spacers on all four tires? What is the advantage of wheel spacers? Does it push the whole rim/tire outwards, therefore moving it away from the chassis? I dont know about those.
What made you choose the 2.5/1.5 versus the 2/3 cornfed?
I know I have plenty questions, but that is what a forum is about.
Hayn4R
It was a combination of those. I wanted an MT. These had a pretty aggressive look to them without being over the top. But they look like they'll do what I want them to do. This is my daily driver also so they have to be pretty decent on the expressway. I have yet to test them offroad but onroad they behave pretty good. Better than I thought they would actually. They also are priced very well. These were ~$190 per tire as opposed to most other MTs which can hit the $250 per tire mark easily.
Yes, I have the Daystar 2.5/1.5. I do not have the wheel spacers yet but they should arrive Monday. They simply act as a spacer between the rim and the wheel. These large tires rub on the upper control arm when I turn the wheel to either lock. Even with the wheel straight I can't fit a finger between the uca and the tire right now. Once the spacers are installed on all wheels, I should have no major rubbing problems. But just in case I've got an angle grinder ready and waiting to shave a little off the front bumper or anywhere else if needed. Do a search for Spidertrax on here or Google and you see them in action. The ones I ordered aren't Spidertrax but they are pretty much the same.
JA explains it better than I.
Hey, ask away. I'm pretty sure nobody on here minds talking about their 4Runner.
AlaskaRuss
