2nd gen 4runner rear hatch
egillette87
I got a 2nd gen 4runner, 1991... having a bit of trouble trying to get the rear hatch to open. I was told the window has to go down in order to open the liftgate, but either the motor sounds tired or something is blocking this... any help on how to bypass the whole thing so I can get the rear hatch to open???
It's been a while since I did mine, but I had to replace the glass in my 2nd Gen's tailgate, and I remember being able to bypass the window lock-out. I believe the locking rod disconnects near the mechanism's pivot/hub, allowing the lock to release regardless of the window's position. Regardless, you will still need to lower the glass at least a little, so it can clear the guide channels on the window frame. As for the window controls, that is very typical of this model--the window supports tend to rust out, to where the motor can barely move the mechanism. Once you get it apart, you should replace the whole mechanism (so you can lower the window properly--otherwise you have to leave the tailgate unlocked all the time).
You can dissconnect the lock mechanism from the inside after you remove the trim and metal cover. I have mine permanently unlocked because I got tired of messing with it. Search "windows" in the Classic T4R forum and you will see that the windows are a common problem.
seltzernator
