2nd gen 4x4 - front actuator wire part number
ltsr
Hey everyone
1992 4runner 4x4 V6 5-speed here. I tried engaging 4-hi and the light on my cluster that usually turns on, did not. I took a look under the front actuator and saw that the wire from the actuator is broken completely in half at the actuator. I just need the harness from the actuator that runs up by the oil filter to the engine harness.
I have been searching for a bit now and still unable to find the part number for it. I believe these threads are talking about the same thing i'm looking for:
http://www.toyota-4runner.org/classic-t4rs/20301-wire-hanging-front-diff.html
ADD 4wd problems. where does this wire go??? - Toyota Nation Forum : Toyota Car and Truck Forums
It's dark out right now, but i'll gladly snap a photo during the day time.
Appreciate any help I can get.
Its pulled out at the connector. I would have soldered and called it a day if it was that simple.
I'm hunting down the tools to take the pins out, get new pins and get it all done. I'll post my fix once its tested.
Here's the final part numbers
Toyota terminal pins (2) 82998-12440
Toyota 2-pin connector 90980-11250
Just used a tiny flat head and popped out the pins and soldered and used new copper wire of the same gauge. Hope that helps future 2nd gen people with the same issue.
Thundro
