2nd gen Intakes
Jhacker1
I'm really wanting to put a intake on my truck but i'm having trouble really finding one. And i don't wanna do a isr i want a legit intake. So please please please can some peeps hook me up with details of their intake setups; pics, cost(if ya don't mind), and difficulty level. thanks in advance!
S& B cold air intake kit
4Runner 3.0, 3.4L (88-95)
this is what I got
Make a snorkel I followed this example. Its really not that hard.
Custom snorkel build-up - YotaTech Forums
This is mine..
Here's a $33 Intake i got off ebay. Wasn't that hard to install, just had some issues fitting the mounts that they gave me. I noticed very little with it though. Throttle response was slightly better, but when you get the rpm's up to 3 grand it felt like there was a turbo kicking in. And it does make a badass roaring sound.
If you want to go the cheapest route, that's what I'd suggest. And here's the linkhttp://www.ebay.com/itm/TACOMA-4-RUNNER-PICKUP-3-0L-V6-COLD-AIR-INTAKE-89-95-/300542991204?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item45f9c21b64#ht_3912wt_1396
index.php
If you want to go the cheapest route, that's what I'd suggest. And here's the linkeBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
index.php
Buying one now, thanks for the tip! Great thread guys. :banana:
index.php
I know you said that you had troubles with the mounts, but what exactly did you have to do? i'm getting one of those intakes and i just wanna know how easy it is.
Thanks.
You know what, I've got a big swim meet tomorrow and I'm gunna be busy all day. But on Sunday I'll take a bunch of pictures and show you how I put it in and how I mounted it in a post. It's soooo easy to do so I wouldn't worry about it.
You should get an instructions sheet with the intake, but here's some things to think about.
This is what the intake looks taken out. It's just a couple bolts plus the attached hoses holding it in there.
DSC05154.jpg~original
This part is mostly just mostly common sense. The new metal hose they give you will attach to the original tubing on the throttle body, then will attach to the mass airflow sensor (square to circle) converter, then to the blue rubber adapter to the new air filter.
And this is where the vacuum lines go to instead the stock airbox.
DSC05155.jpg~original
As for the mounting.. I originally just used one of the metal extended mounting bracket they gave me and "willy-digged" the thing on there in my own way. And as I was out there taking pictures of everything, I notices my mount snapped off! But because of where it is, it's just sitting in there and not moving around much. I'll end up making my own little bracket for it eventually.
DSC05163.jpg~original
DSC05165-1.jpg~original
The rest is explained in the directions. Pretty easy install.
are these things seriously 439 $ usd ?
index.php
4runnertank,
Can you snap a picture of the engine bay and the intake and can ya give me a quick summary of what you think about the intake. pros cons all that fun stuff.
THANKS!!!
Hey man, thanks for all the awesome and helpful pics. Mine hasn't got here yet, but I will most assuredly check your references again when it does get here. You rock!
Mass airflow sensor
If you want to go the cheapest route, that's what I'd suggest. And here's the linkTacoma 4 Runner Pickup 3 0L V6 Cold Air Intake 89 95 | eBay
index.php
Hi, how did you connect your mass airflow sensor to the eBay aftermarket intake?
Well, did some searching and figured it out how you did it. Was hoping anyone knew if the sensor itself unscrewed from the assembly and connected to the aftermarket tube somehow?
if you've got a 3.0, then you dont have a mass air flow, you have a vane air flow meter, and so it is all one big "sensor", and it doesnt get any smaller than it already is. You can move it around and position it to better fit a cone filter if you want, but don't try and take it apart.
If you are looking for an idea of what some people have done, search for "ISR mod" (intake silencer removal) and that should get your started.
Jesse1
